EDIT: Added L35, N30, Blitz w/new bulb (with crushed off return wire insulator) and Locator HID Found a new test range close to the house and wanted to give it a test run. Conditions were not great due to an 8 knot wind and lots of small particulates in the air so visibility and throw performance would have been better. I used 4 and 5 second, F3.8 exposures and when I look at the pics, the hotspots look very representative at 5 seconds but there was much more peripheral spill that is not showing up. I just noticed I used F3.5 for the added shots. I thought they looked just a tad bit brighter but not by much.
Control, no zoom: (Iphone photo) Square=350yd, Circle=900 yd, Triangle=1115 yd
Control, Zoomed (Iphone Photo)
MaxaClone 75 Watt HID @ 350 Yds - Straight Tube bulb This light is hard to start and the bulb flickers on low. I had to make a focusing extension for the stock bulb because the focusing knob would shove it forward enough. Also, I had to carefully move the front glass around (and so the front bulb alignment nub) because the glass is smaller than the I.D. of the bezel ring making it "float" and end up not perfectly centered which greatly effected the tightness of the spot. Even centered, to me, it does not focus as I believe it should. I'd love to borrow a true Maxabeam because I believe it would perform miles better! Parker VH's Ushio bulb adapter arrived today so I'll mod in the Ushio and give it another shot.
I could not find the 900 Yd. or further targets with the MaxaClone so no pics. Maybe when I get the Ushio bulb installed.
Maxaclone 75 Watt HID with Parker VH Ushio bulb adapter and Ushio bulb 350 Yds. Clearly, the Ushio performs far better than the straight tube bulb the clone came with. It's even more dramatic in-person. I could tell when I carefully collimated and focused the light in the garage, that the hotspot was now down to about 2" @ 20 feet, whereas the straight tube bulb hotspot was about 4 or maybe 5".
Maxaclone 75 Watt HID with Parker VH Ushio bulb adapter and Ushio bulb 900 Yds. Cropped and enlarged in Photoshop, I could see the spot on the tree. I would not really call it usable at this distance.
Maxaclone 75 Watt HID with Parker VH Ushio bulb adapter and Ushio bulb 1115 Yds. Again, cropped I could see light on the target but definitely not usable by humans at this distance.
Maxaclone 75 Watt HID with Parker VH Ushio bulb adapter and Ushio bulb 1780 Yds. over 1 mile. Yes, enlarged, I barely saw light on the target but that's it.
N30 32 Watt HID @350 Yds.
L35 35 Watt HID @ 350 Yds.
AmondoTech 46 Watt HID (3152) ((POB)) @ 350 Yds. Using the original Costco HID 6000K bulb overdriven at 48 Watts.
Vector 192 150 Watt HID @ 350 Yds. This is my modded twin 75 Watt, Philips FatBoy bulb'd light running at 3900K. It took this test range to show me how powerful this light really is. It's now up high on my favorites list.
Vector 192 150 Watt HID @ 900 Yds. If you look close, you can see the tree.
Vector 192 150 Watt HID @ 1115 Yds. If I were standing to the side and using binocs, I believe I could see the 1115 Yd. treeline glowing a bit.
LarryK14 600 Watt Incandescent @ 350 Yds. This LarryK14 uses a GE Q4559X 28 Volt bulb and is driven by a 44.4 Volt (Nominal), 12S/1P, 5300 mah Lipo pack thru JimmyM's 70Volt/40Amp regulator board. In the pic, it is running at precisely 29.8 Volts at the bulb - around 650 Watts.
LarryK14 600 Watt Incandescent @ 900 Yds. The tree is visible, you have to look closely. Look how much of the 900 Yrd hill is visible! The 900 Yrd. hill is even visible in the 350 Yrd. shot.
There is so much peripheral light given off by LarryK14, that I could not see the far treeline. Again, I'd guess with binocs and standing away from the light, I could see some glow. No Pic.
Blitz, 84 Watt HID @ 350 Yds.
Blitz 84 Watt HID 45 Watt @ 350 Yds.
Blitz 84 Watt HID @ 900 Yds. 84 Watt
Blitz 84 Watt HID @ 1100 Yds. 84 Watt (The hill behind the tree)
Locator 350 Watt HID @ 350 Yds.
Locator 350 Watt HID @ 900 Yds.
Locator 350 watt HID @ 1100 Yds.
Non-Standard distances:
Blitz @ 700 Yds. 84 Watt
Locator @ 530 Yds.
Locator @ 700 Yds. to tree on left, 750 Yds. to tree on right - looks like my aim was a bit low.
Locator @ 530 Yds.
