Uniqe Titanium
Page 6 of 10 FirstFirst 12345678910 LastLast
Results 151 to 180 of 288
Thread: Polarion Abyss Dual "S"
  1. #151
    Jul 2011
    Hong Kong
    Default Re: Polarion Abyss Dual "S"
    The problem about this light is changing the Lamp , it supposed change by Polarion
  2. #152
    BVH's Avatar
    Sep 2004
    CentCalCoast
    The lamp ought to last at least 2,000 hours. I'd guess that would be 3-6 years down the road, probably more.
    G.E. 1942A WWII 60" Anti Aircraft Carbon Arc (Sold), 1KW Marconi Radar Sys Short Arcs, 1KW VSS-3a Tank Light, 600 Watt M-134 Gatling Gun Short Arc, 175 Watt Megaray, 300 Watt "Locator's", 150 Watt Short Arc Communicator, Maxabeam 12MCP, LarryK14@52V
  3. #153
    Jan 2006
    Arnieland
    Quote Originally Posted by BVH View Post
    Not to mention these bulbs can sustain pretty heavy abuse. I can only imagine how long the ballast will last. I want to say a lifetime but realistically I would guess 20~30 years with good use.
    Funniest CPF thread ever. I promise it'll make your day.
  4. #154
    Jul 2011
    Hong Kong
    Will you often turn on th light ?
  5. #155
    Not sure if it is okay to post this but..... there is a ebay store selling the Abyss at a great price if anyone is interested. They say 9 in stock. I am not affiliated at all, just FYI. Mods, feel free to put this wherever.
    I miss my PH40.....
  6. #156
    Jan 2006
    Arnieland
    Quote Originally Posted by sledhead View Post
    I miss my PH40.....
    It's MSRP now. Even at the previous price I would've still bought from Ken. I've learned from my mistakes.
  7. #157
    Flashaholic* 276's Avatar
    Nov 2006
    CT
    So far its been a little over a month since i have store the light with the battery out. Its a 15.44 Volts and has four leds lit.
    Surefire,Inova,4Sevens,Fenix,Olight,Malkoff, AEX25,Xeray50,Polarion Aybss Dual, AElight 30-50 watt,Wiseled tactical 2000,Peak, Lupine Wilma TL, .......
  8. #158
    karlthev's Avatar
    Nov 2004
    Pennsylvania
    Jan
    Karl
  9. #159
    karlthev's Avatar
    Nov 2004
    Pennsylvania
    Jan 20th, 2012, 7:52 PM 14.41 volts. One LED lights when the Polarion is turned on then it blinks and then goes out.....I'm thinking a bad battery. Thoughts gentlemen?
    Karl
  10. #160
    Jan 2006
    Arnieland
    Quote Originally Posted by matthewcyho View Post
    Have you own one too ?
    No, but I do have a PH50.
    Quote Originally Posted by karlthev View Post
    Karl
    I'm sorry to hear that. I'm confident Ken will make it right, he always has.
  11. #161
    karlthev's Avatar
    Nov 2004
    Pennsylvania
    2/5/2012 7:00 PM Ran for 35 minutes 13.80 volts
    Karl
  12. #162
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    Karl
    You began your test on 11/29 at a slightly low charged voltage of 15.4V or about 3.85V per cell if averaged out, and 5 LEDs displayed. Two months later your battery pack is 14.4V or 3.60V per cell average, and displays 1 LED. I think you have an unhappy battery, not specifically because it lost .25V per cell but over two months but because it didn't charge properly to begin with.
    It's obvious that all of our packs are draining if stored inside of the light, as I verified once again after bringing it out for a desert hike last week. The battery was drained to a single LED once again after two months. I didn't check the voltage because I was in a hurry to get packed for my trip and needed to recharge the battery. A question that remains is if the self drain issue continues to drain the cells below 3.0V thus permanently damaging the cells. I suspect that although the auto turn off feature exists specifically to protect the cells during normal use, there's probably no circuit to prevent parasitic drain, which could potentially drain the cells down well below 3.0V. It's possible that's what you're dealing with now Karl, a damaged battery due to over drain on a previous occasion, before we were aware of the self discharge characteristic.
    I remember before they fixed the original WiseLED Tactical, that would self discharge itself into oblivion as well and would destroy batteries. With that light we didn't have the option to remove the battery pack so the only answer was to leave it on the charger all the time when not in use. Not practical at all.
    Certainly, I would love to be able to leave the battery in my Abyss when stored, just like the PH50, but it seems that's going to be a no, no.
  13. #163
    BVH's Avatar
    Sep 2004
    CentCalCoast
    Quote Originally Posted by Patriot View Post
    I agree with Patriot on the 3.85 Volts per cell charge. There are many, very knowledgeable "battery-savy" people on RC Forums. It's pretty much the rule there that when a Lipo is not in frequent use, it's "storage charged" at 3.85 Volts per cell, give or take a hundredth. It is known that 3.85 Volts per cell is about 50% charged or maybe a bit less. At 3.6 to 3.7 Volts per cell, there isn't much left. It would appear as though your pack started its' test at about 50% state-of-charge.
  14. #164
    karlthev's Avatar
    Nov 2004
    Pennsylvania
    Agreed. I think there was irreparable damage when the pack was inadvertently drained to zero charge and that is unfortunate. I will try to recharge and discharge several times--as you had suggested previously--to see what may result. I just don't seem to have the regular use needs which would lend itself to repeated, regular chargings. As Patriot has said, that may "force" us to remove the pack to avoid damage to future packs.
    Karl
  15. #165
    Flashaholic AEHaas's Avatar
    Dec 2009
    Sarasota, FL
    All the magnetic switch lights are going to use a little bit of current so recharging every few months to keep them topped is needed if you leave the battery inside. I find that I am using the Abyss more than the PH40 now. If anybody wants the PH40 without the case for $1,600.00 you can have it. I will keep the large case for the Abyss and my filters et cetera. PM me.
    aehaas
    The most valuable machine guns in the world. Home Inspection, whole house approach, Sarasota Home Inspections, we are your investigators.
  16. #166
    karlthev's Avatar
    Nov 2004
    Pennsylvania
    "Fully" (?) charged up the pack tonight to 16.03 volts. Leaving it OUTSIDE the light....just to see....
    Karl
  17. #167
    Feb 2007
    Arizona
    Karl
    16.03V is still a bit low. Hot off the charger I'm getting 16.67V. You might check the output voltage of your charger just in case. Still, I'm curious to see if your battery pack holds expected voltage while outside of the light.
  18. #168
    karlthev's Avatar
    Nov 2004
    Pennsylvania
    I'll be keeping all apprised. In the meantime I have submitted a ticket to Polarion with my concerns. I ordered this light May 11, 2011 and to see there are difficulties at this early date, PARTICULARLY with so little use is most disconcerting! We'll see what happens....
    Karl
  19. #169
    Nov 2006
    CT
    After two months of storing mine outside of the light the voltage was 15.11 and i am down to two led's.
    alex
  20. #170
    This looks like an awesome light. I want one.
  21. #171
    OT post removed. Thread is about the Polarion Abyss Dual "S". Please start your own thread re the other spot light if you wish.
  22. #172
    I ordered it today. Hopefully it will ship tomorrow and I'll have it by the end of the week. EEEEHaaaa
  23. #173
    Feb 2007
    Arizona
    Quote Originally Posted by MDJAK View Post
    Please post your thoughts and pictures when it arrives. I know you'll love it!
  24. #174
    Double Posted
  25. #175
    Anyone of you upgrading to the Abyss have a PH40/PH50 they want to offload? I'm more than glad to take it off your hands
    (Apologize if this double posts - IE froze as I submitted)
  26. #176
    Unenlightened
    Oct 2009
    south australia
    I have just ordered one today ,upgraded to a hard case ,spare battery and red filter for spotlighting foxes , my rational was why pay out for 3 or 4 big LEDs when this one will do it all , hope it arrives soon
  27. #177
    Darn, Phil, now I'm envious. I didn't get the hard case. I opted for the soft case. I never use the hard case that came with any of my equipment, be it big white Canon lenses for my main hobby of photography, or even the nice hard case that came with the SR90. I'm interested to see what the soft case is like.
    As to an extra battery, I'm sure there's one in my future. Right now I use my lights for approximately a 45-50 minute walk each night so one should suffice. I hope.
    Patriot, I will def take pics when I get it. Ken emailed me and said it may ship today. They didn't have them in stock when I ordered it so they have to get them from Polarion and then ship it out. I'm dying that I didn't pay for faster shipping. I ordered it UPS ground, which if it's coming from California to NY, where I live, it will take a week. But I hate to waste money on faster shipping. Rather put that toward something material. Like an extra battery. lol.
    Quote Originally Posted by luckyphil View Post
  28. #178
    BVH's Avatar
    Sep 2004
    CentCalCoast
    If you don't specifically need a second battery for your operations, I'd get only one and use the heck out of it. When it wears out, get the second one. Having 2 at the same time will cause non-use aging to be a higher factor in the finite life of both batteries.
  29. #179
    Feb 2007
    Arizona
    +1 to this.
    A while back I was thinking of ordering another but it seems that I never need more than 50-60 minutes of HID light. If I need more light time, a compact LED will usually suffice. I guess I sort of use my HID's (especially the Polarions) as special purpose weapons. Guns vs. rifles.
  30. #180
    Unenlightened
    Oct 2009
    south australia
    just thought it would be handy to have a charged battery when out spot lighting all night but maybe ill wait and see if i need it before i charge it the first time , also getting one @ $135 with the abyss was a good deal and saved on postage
