gustophersmob
- Joined
- Jun 21, 2009
- Messages
- 92
Howdy all!
I want to assemble my ideal version of a pocket light and was hoping to get some feedback and advice.
Currently I have an HA pocket-body Matterhorn and an HA pocket-body #8 Eiger. I really like the Eiger (it is my EDC), but there are many times the #8 level is just too much. I'd like something with less output. The problem is that ideally, I want both high and low outputs in the same light. I've tried some other multimode lights, but I keep coming back to the Peaks.
So here is what I am thinking. I'm thinking of something along the lines of a SS #8 Eiger medium optic, cool tint in either lug or keychain body, but adding a QTC pill to give me infinitely variable output. This is where my questions start…
1) Which body would be best to use with the QTC? I like the idea of the lug body, since it is one piece and simple, but the keychain would let me adjust the neg. terminal height to accommodate the QTC pill. Is the negative terminal adjustment essential to get the head's o-ring to seat all the way when adding a QTC pill?
2) By adding what is essentially a resistor in series with the power supply, would running a #8 Eiger at a really dim level be inefficient and lead to reduced runtimes?
3) Where is the best place to source these? I'm assuming RMSK for the Eiger, since it is a standard version, but where can I get the QTC easily?
4) I read the post where Curt says that Peak has designed a QTC module specifically for the lights, any ideas when this will be available?
Thanks for any additional advice or help you can give! :twothumbs
