Steve K
hi gang,
I'm in the mood to rig up a bit of lighting for the home. I've got 4 XP-G's and a few yellow LEDs that were scavanged. The plan is wire them in series (nominally), running at 1.5A and a total voltage for the string somewhere around 12 to 15 volts.
I'd like to keep the package compact and easy to retrofit into the volume of a normal fixture. I could make life easy and just use a large wall-wart transformer to produce roughly the correct voltage, but these tend to be bulky and heavy. My preference would be to use a switcher IC and put together a basic high voltage buck converter. No need for dimming or anything fancy. Just a simple converter that would use easily obtainable components, i.e. no special transformers.
I've been browsing through a few of the IC manufacturer's sites, but haven't found anything that seemed ideal just yet. I did find an app note for an OnSemi part, the NCP1216, where it was used for a 0.5A circuit. Seems like it could be modified to 1.5A.
http://www.onsemi.com/pub_link/Collateral/DN06050-D.PDF
What else is out there? Is there already a design worked out that is not too hard to build?
thanks much,
Steve K.
thanks much,
Steve K.
