NITECORE -- Keep Innovating
Page 1 of 2 12 LastLast
Results 1 to 30 of 60
Thread: My new Klarus Mi-X6
    Default My new Klarus Mi-X6
    Greetings all!
    I've been lurking/researching here for awhile. I was looking for a replacement for my Arc Premium. I had it narrowed down to the iTP A3 EOS, Preon Revo, and the Klarus.
    I chose the Klarus even though reviews were scarce (except for the excellent video from Going Gear), because it has a steel body, and no PWM.
    Even before I knew what PWM was, I knew the "flickering" as I called it, drove me nuts. I'm glad I chose the Klarus. This is an outstanding little light!
    Here are some pics. I apologize for the quality. My first product/beam shots with a new camera.
    In the box (Sorry, no actual unpacking pics. You get the light, extra O-ring, extra split-ring, and manual. No battery):
    Next to my Arc:
    AA battery/Arc/Klarus
    Tops popped on both (notice the lack of a foam ring on the Klarus, more on that later).
    Orange Peel (out of focus ...sorry).
    Keychain tools:
    I have limited space, and gloss painted walls, so these aren't the best beamshots, but hopefully they'll give you some idea of the beams on the Klarus. (All lumen levels are quoted from Klarus)
    All shots using a Duracell AAA Alkaline (All I had on hand):
    Klarus: Med (26 Lumens) / Arc
    Klarus: Low (3 lumens) / Arc
    Klarus: High (85 lumens) / Arc (Wish I had more room. The Klarus devours the Arc at this point).
    KlarusMi-X6
    Pros:
    >Very light, yet strong steel body
    >Brushed steel. I was afraid that the light would be slippery without any knurling, but the brushed steel is pretty grippy. The logo helps as well. Running my thumbnail over it, it almost feels like slate.
    >Nice throw for a keychain light, high lights up a whole room
    >Lamp is well-centered
    >Runs M-L-H-Strobe, which I prefer (except for the strobe, not sure I'll ever use that)
    >Perfect size for a keychain light
    >Waterproof to IPX-8
    >No PWM!
    > Doesn't skip levels even when twisting very fast
    Cons (for me):
    No foam ring on head (mentioned in pic above) means that when the light is off, the battery rattles slightly. Not much, but it's there.
    All in all I'm really happy with this light. Fit and finish is great, and it seems to be a solid little light that will last.
    Thanks to all the hard work and research by the members here that helped me decide.
    Moderator
    Feb 2003
    CA
    Default Re: My new Klarus Mi-X6
    Very nice first post. I can tell that you have been lurking, and learning. Good review.
    Bill
    Default
    Hey thanks for the awesome review, was wondering why there wasn't much talk of the X6 around here. Could you point me to where I could buy this light online?
    Mar 2007
    Lake Como, Italy
    Hi Degaeil and
    Your pictures are actually better that what you claim, thanks for sharing them.
    The rubber ring that acts as a spring and is stuck to the back of the head is missing in your specimen, this is not normal. I would first check well that it is not loose in the box and if it is not there I would send an email to Klarus asking for a replacement. It is unlikely that a dealer carries spare ones. In the meantime you can wrap the battery in a Post-it to avoid the rattle.
    I have been carrying my X6 for more than a month now and I am pretty happy with it. I hang it from my neck under the shirt with a thin rubber cord, alternating it with the X5 which definitely thinner.
    Apurva: I bought my Klarus lights in the UK from taclight.co.uk
    Default
    Nice review! I've been tempted by this light, but have held off because I don't know if it can handle 10440. It's "not recommended", but unclear whether it's Thou Shalt Not, like the Preon Revo, or Thou Ought Not, Unless Thou Art Careful Not To Let Thine LED Overheat, like my beloved iTP A3.
    Thanks for the welcome and the comments!
    apurva: I bought mine at goinggear.com
    Kilovlolt: Holy cow! You're right! I just watched the review from Going Gear again, and there it is. I checked the box, and it's not there ...rats. I guess I'll email Klarus, although I may give Going Gear a shot.
    Thanks for the heads up.
    flashflood: 10440? I couldn't tell you. I'd be hesitant to try, and honestly even the alkalines produce enough light for my use. I'll probably get some Ni-Mh's for it.
    I'm wondering if the steel might result in too much heat inside the body.
    Jan 2010
    Melbourne, Australia
    Hi degaeil.
    I have the Mi X6 and I agree with you it is a fantastic little light. Just wanted to mention that mine has got the little black pad to stop the battery rattle, so you might want to get in touch with Klarus. Their customer service is absolutely fantastic. I had to contact them when I got my Mi X5 because I needed some replacement O-Rings (kept tearing) and they were dispatched pronto.
    Flashlight Selection Process: Pick any two, and only two of the following: Bright, Cheap, Long-Runtime.
    Thanks bedazzled. "Their customer service is absolutely fantastic". Good to know. I've sent them an email with my address. Hopefully they can just pop one in the mail for me.
    Interestingly enough, the 1/2 inch (diameter) battery retainer from the Arc-AAA fits the Klarus perfectly, and the pressure sensitive adhesive lets you remove it and put it back on, but just a few times I'm guessing. I don't really want to cannibalize my Arc for this, though.
    If, for some reason, Klarus doesn't come through for me, I may contact Arc and see if I can get another one from them for a few pennies.
    I suppose I could just return the Klarus to Going Gear for a replacement. I've got 12 more days to do that.
    I'll see if Klarus get's back to me by mid-week. Keeping all my options open.
    i think the foam pad is also the reverse polarity protection. and you may need a suitable glue.
    Flashaholic* HIDblue's Avatar
    Mar 2010
    California
    Nice review and photos. Always wondered about the Mi-X6 since I'm a sucker for stainless steel lights. How does the twisty UI feel? Is it pretty smooth?
    My dog ate my flashlight...
    HIDblue, It's really smooth, and no matter how fast I twisted it, it never skipped a mode.
    Update to the retainer pad issue: I emailed both Klarus and goinggear.com.
    Have not heard from Klarus yet, but Ryan from Going Gear emailed me and said I needn't bother with a return authorization number.
    Just send the light back with a description of the issue, and they would refund or replace.
    Very impressed with the speed of communication and service from Going Gear.
    So, rather than wait for a new pad, I'm going to send the light back for a replacement.
    Even with this issue (mistakes happen), I'm still really pleased with the Klarus.
    Mar 2010
    California
    That's great to hear on both fronts. I may have to pick one up for keychain duty. And I've had nothing but stellar dealings with the folks at GG. Thanks.
    Well, all's well that ends well.
    Got a new Klarus back from Going Gear today, and...
    As you can see, Battery Retaining Pad included.
    and a well-centered lamp in this one as well.
    With everything sorted out, I'm really impressed with this little AAA.
    Mar 2007
    Lake Como, Italy
    Very good Degaeil, enjoy your X6 as I keep on enjoing mine!
    Au Re: My new Klarus Mi-X6
    Which is better:
    Klarus Mi-X6 with Sanyo Eneloop
    or
    4sevens Preon Revo with Sanyo Eneloop
    Mar 2007
    Lake Como, Italy
    Quote Originally Posted by agoston.berko View Post
    Which is better:
    or
    My Revo's beam is slightly more concentrated than the X6's one which is a bit floodier. Apart from that I don't see much difference. Maybe we can help more if you clarify your requirement and/or definition of 'better'
    BTW:
    Wink2 Re: My new Klarus Mi-X6
    thank you for helping...
    very kind
    i want to use sanyo eneloops. i would only use it as a keychain light.
    could u send a pics next to each other (4Sevens ReVo and Klarus Mi X6) ?
    the specs say that klarus is smaller in volumen but a bit taler ! is that right ?
    which feels in your hands more "high"-quality ? which u like better ?
    which is easier to turn on/off (onehanded) ?
    are the nearly the same in thoughness ? (water, drop)
    how much is the warranty on them ? 1-2 years ?
    does anybody familiar with the "new" BLACK edition sanyo eneloops ? are they also in triple A version available ?
    klarus mi x6 is stainless steal, right ?
    but the revo has also aluminium finish - which i prefer (heat transition, weight, corrosion)
    so its a tough call for me to decide (they cost the same), but i don't want to get both...
    first i wanted lummi wee or drake or draco, but they are hard to get and cost a fortune. and the other bug disadvantage that they use weird batteries.
    i prefer common batteries, like AAA
    or are there any better alternatives beside this 2 flashies ?
    THANK YOU VERY MUCH (please post pictures from every angle)
    Mar 2007
    Lake Como, Italy
    Let me try and answer some of your questions.
    Size of the two lights is very similar with the Klarus only slightly slimmer. As an EDC I like better the X6 because its steel body is less prone to accidental damages, which is important if you keep it loose in a pocket or attached to your keys.
    One-handed operation is more or less the same for the two.
    Sorry I do not use Eneloop cells because I tend to favor lithium primaries, they keep their charge for much more time and besides a very small light tends to be used sparingly so cost is not an issue. I can't see anybody walking their dog with a 1 x AAA flashlight in their hands.
    I see, very similar...
    Thank you for the picture.
    Is it not dangerous to use lithium in steel body for a too much period of time ?
    I think the eneloops are such a nice batteries to save a bit the enviroment and save money at the same time... If the sanyo solar charger will come in the EU i will buy one for sure. The new eneloops can be charged 1500 times. That's amazing !
    U probably know that the ReVo also available in STAINLESS STEEL...
    If u had a chance to choose between ReVo SS and X6 (also SS), would u again more tend to the Klarus ?
    Mar 2007
    Lake Como, Italy
    First of all let me clarify that I was talking of lithium primaries i.e. 1.5V Energizer Lithium batteries which are perfectly interchangeable with alkalines or NiMHs.
    Now that you remind me, yes I knew that Preon Revo is also available in s/s but I still vote for X6 because its body design is different from the one of other lights of the same size and I have too many of them that look the same.
    BTW: where are you based in the EU?
    i'm from Hungary
    Thank you very much Kilovolt... you helped me a lot
    I will order the Klarus Mi X6... the design is more appealing also to me ! i like slim EDC's
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    What might also be important is if you like low/medium/high or medium/low/high/strobe sequence.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Mar 2010
    California
    I know Klarus does not recommend it, but out of curiosity, has anyone tried using a 10440 in their Mi-X6?
    Looks like someone else here has been considering Klarus like me. Nice to see one's opinion who owns both the Revo and the Klarus ...... hmmmm decisions decisions. Thanks
    'AN EDUCATED BUY IS A GOOD BUY'
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Lightman2 View Post
    I could not really reach a decision and got them all:
    Klarus are nice light, maybe because they are rather heavy inspired from the ReVO.
    Sep 2007
    MA
    Exactly... I think that would be one of the first thing to decide for most people. I have a Revo SS, it's nice, I'll get the Mi-X6 very soon. I like ML-H sequence best, but like how Strobe is hidden on Revo. I don't know who's making the Revo for 4-Sevens, but it's clear that it comes from the same place as the Klarus lights (I don't think it's a design ripoff).
    Mar 2007
    Lake Como, Italy
    In presenting the new brand a few months ago the Klarus people said that they had been making flashlights for others for some time and they wanted also to be present on the market directly.
    In fact Revo and Mi10 are so similar that once I had mixed heads and bodies out of curiosity I was no longer able to tell which was which so that I had to go and look at the site pictures to put the right head on the right body.
    As to level sequence, personally I hate EDC lights that come on too strong but this is not applicable to very small keychain types that are used quite occasionally to find a key hole or a fallen thing. I find that the initial low level of the Revo is useless in 90% of these cases and I surely prefer a medium level at switch-on.
    i ordered Klarus Mi-X6. i hope next week it will arrive.
    i'm looking for a nice and SMALL pull-reel (or something like that) - like that i can search for keyholes (keep distance from keychain)
    anybody has an idea ?
    stainless steel would be a perfect match for the keys and the Klarus ...
    where to buy that accessory ?
    Whats your favourite HKJ?
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    For key chain duty I prefer a medium first light and I also prefer to stay with the more common battery sites, this makes the MiX6 my favourite.
    All the lights has some strong points, depending on what you prefer:
    ReVO, Mi10: Knurling for a better grip.
    MiX5: Small size, much better for a small key chain.
    ReVO: Warmer led for better outdoor color rendering (That was a limited run).
    ReVO, Mi10, Preon: Low/medium/high sequence.
    MiX5, MiX6: Medium/low/high/strobe sequence.
    ReVO, Preon, Mi10, MiX6: Uses a common AAA battery.
