Originally Posted by
Illum
The reflector is a two stage, with the lower lamp around a steeper cone, but the steeper end is only as deep as half of the lamp height. It is not focusable. At minimum I'll figure out [eventually] how the ring is charged, and possibly running it off a pigtail and a spare 18AH SLA I have kicking around. The head is heavy enough to tip everything over without the battery in the battery box. 4 of the 6 screws have the sockets stripped from corrosion. 1 of the screw's threading socket [whatever it is called] pulled out of the bottom enclosure [pic 5]. Only one screw managed to function properly. I've pulled some hardware from dumpster before, but finding matching sockets might be difficult. I suppose I can epoxy free-riding hex nuts in there, but we'll see.
The window appears to be polycarbonate, it is certainly not glass. The outer rim to rim measures 7.5" and the inside rim 6.5" Since the window retaining ring is cracked all around the edge [you can see the small fissures on pic 4] I was afraid of taking that part apart. I'm guessing the window underneath it is at least 7"
The lamp replacement hatch is water tight with a rubber o-ring of sorts, spring loaded bayonet lid. The lamps aren't bipins, they have a funny sort of terminal that are connected with spade connectors under screws.
I have local ties that grants me permission to fish out stuff that I can use [I'm a hobbiest and a tinkerer of sorts], provided that I do not sell it because some of these things are coded. The security guard there will turn a blind eye as long as I go there only on weekends, and not get hurt. If I wound myself in there, he will have no choice but to arrest me for trespassing.
