EAGTAC
Page 1 of 2 12 LastLast
Results 1 to 30 of 32
Thread: Are LED light's circuit board shielded against strong EMF and RFI?
    Apr 2011
    The Pale Blue Dot
    Default Are LED light's circuit board shielded against strong EMF and RFI?
    As titled, does strong EMF and/or RFI has any effects on LED flashlight's onboard circuit board whether they are current limiting or PWM type?
    Thanks.
    Jul 2010
    Sydney, Australia
    Default Re: Are LED light's circuit board shielded against strong EMF and RFI?
    If it's inside a metal case, it should have reasonable shielding.
    Flashaholic* mrlysle's Avatar
    Mar 2011
    West Virginia
    HDS systems lights are supposed to be able to survive an EMP. Hope I never have to find out if mine will!
    Jeff
    Apr 2011
    wouldn't alimunium be useless due to it having no magnetic proterties?
    *Flashaholic* Sgt. LED's Avatar
    Sep 2007
    Chesapeake, Ohio
    Way too many threads been made on this topic and they all get closed.
    Mar 2011
    West Virginia
    Have a look at the new SL series lights from Spark. They advertise EMF/RFI shielding in bold print! WTH?
    Jeff
    Jul 2010
    Sydney, Australia
    Aluminium will not shield from Magnetic Fields, but the question was about Electromagnetic in general and Radio Frequency specifically, which are stopped by Alumium.
    Aluminium is regularly used fro shielding electronic equipment.
    Light is one example of Electromagnetic Field radiation.
    Jul 2010
    Sydney, Australia
    Quote Originally Posted by Sgt. LED View Post
    Really ?????
    *Flashaholic* PhotonWrangler's Avatar
    Oct 2003
    In a handbasket
    Quote Originally Posted by ganymede View Post
    Thanks.
    1) Find a portable AM radio.
    2) Tune it to an empty spot at the low end of the band.
    3) Turn on the flashlight and hold it up to the radio's antenna.
    If you hear the flashlight's PWM circuit buzzing in your radio, EMF is getting out. And if EMF can get out, it can also get in.
    Flashaholic* LedTed's Avatar
    Mar 2010
    Britannia
    Thank you PhotonWrangler,
    This is the best response I've read yet!
    Sincerely,
    Enjoy the light show - LedTed
    Flashaholic* AnAppleSnail's Avatar
    Aug 2009
    South Hill, VA
    Quote Originally Posted by PhotonWrangler View Post
    Depending on frequency (wavelength). I'm not an EE so I can't tell you if low-frequency (long-wavelength) EMF is a problem, but a conductive shell with holes of a given size can block EMF over a certain frequency, that frequency being based on the hole size. Now, I have no idea if that matters or if I'm just being pedantic.
    I am not able to really evaluate this source, but it seems coherent and discusses EMP testing:
    ECE.unm.edu
    Apparently it's not really feasible to test with a nuke, which causes an EMP mainly by slamming gamma rays into the atmosphere, releasing electrons at high speed, generating a magnetic field very quickly, which pushes the Earth's field rapidly to cause damage to things. Instead we use electronics to generate an EMP, like a
    In short:
    EMP generation outside controlled tests are hard to predict and plan for. I see lots of people talking about testing this or that, but not much real data. Give these guys a call:
    DtB Testing
    Research EMP effects and physics to plan for post-EMP lighting.
    My biggest light-hog is my camera.
    Apr 2011
    The Pale Blue Dot
    Guys,
    Thank you all for the great inputs, the main reason I am asking this question is because some flashlight manufacturers advertise their lights as designed to "Mil-Spec", so I am assuming a piece of equipment designed and tested to military specifications generally speaking are shielded against some EMP and RFI no?
    LED flashlights are great, great runtime and super bright but if a burst of EMP or RFI can potentially fried out the circuit board are they (LED) still the preferred choice? Quoting Murphy's law here, things that can fail will fail. Keeping things simple, any assault rifles can fail but not a bayonet.
    Oct 2003
    In a handbasket
    More food for thought -
    One point of ingress and egress for EMI/RFI is directly through the lens, which by definition is not made of metal. While a thin coating of a conductive material can be vapor-deposited onto the lens, this will only provide very weak protection against electromagnetic fields. Anything that has a lens is vulnerable because of the lens.
    As an example, many years ago I was running a video camera at a live event on an outdoor stage. It just so happened that the event was being held a half mile away from a radio station's transmitter tower. While the camera's body was very well shielded and did a great job of deflecting RFI, any time I pointed the lens in the direction of the tower I got a screenful of hash. There was no way to shield the optics from the RFI.
    Apr 2011
    The Pale Blue Dot
    Unless you block it with a block of lead! Haha! Just kidding!
    Flashaholic* CarpentryHero's Avatar
    Jul 2010
    Edmonton
    So than an emf resistant light may also be ghost resistant?
    I'm glad I found CPF, I was beginning to think I was strange
    I'm a Canadian and a proud Flashaholic
    Thanks CPF, thanks Think2x
    Flashaholic HooNz's Avatar
    Mar 2011
    Australia (Near the Black Stump)
    Guys,
    LOL , mil-spec , i can just imagine a "opposition" parked away from a base with a Df directional antenna with a receiver that tunes from 30khz to 400khz or so listening out for those on low power or moonlight mode using PWM .
    Positioning!
    I've seen em!
    Apr 2011
    The Pale Blue Dot
    Quote Originally Posted by HooNz View Post
    Positioning!
    Interesting! Did we unknowingly gave our position away to our enemies?
    Apr 2011
    The Pale Blue Dot
    Quote Originally Posted by CarpentryHero View Post
    Lol! No more "possessed" flashlights that turn on or off by itself?
    Ehm... One TK11 had a problem that its led started slightly shining, very dim, when I put it onto the shelf... And it has a pretty thick body...
    Apr 2011
    The Pale Blue Dot
    Guys,
    Seems like the latest and greatest light the Scorpion V2 is suffering from the problem of EM interference:
    http://www.cpfmarketplace.com/mp/sho...-start-the-car
    You can turn it on with a magnet ala iPad! iScorpion anyone?
    Oct 2003
    In a handbasket
    If they're using Hall Effect sensors as that thread indicates, I would expect it to be activated by strong magnetic fields. On the one hand this is an interesting design and was probably done for reliability - get rid of the mechanical corrosion-prone metal contacts and perform the on/off switching with a solid state sensor. This will enable the switch to provide reliable service for a long, long time. On the other hand, they probably need to include some mu-metal shielding around the Hall effect sensor to prevent accidental activation from external magnetic stimuli.
    Jul 2010
    Sydney, Australia
    Thank you all for the great inputs, the main reason I am asking this question is because some flashlight manufacturers advertise their lights as designed to "Mil-Spec", so I am assuming a piece of equipment designed and tested to military specifications generally speaking are shielded against some EMP and RFI no? . . . .
    No. There are thousands of Military Specs - unless they say which part of which Military Spec it complies with, it's one of those brilliant Marketing strikes - makes the customer believe wonderful things about the product, and if challenged, they justify the statement by giving one trivial example of Spec compliance.
    Jul 2010
    Sydney, Australia
    . . On the other hand, they probably need to include some mu-metal shielding around the Hall effect sensor to prevent accidental activation from external magnetic stimuli.
    Exactly - the results show that there was inadequate field testing of the design - typical customers are having serious problems - a flashlight turning on and flattening the battery is a serious problem.
    If the problem only happened close to an MRI machine, you could accept it, but not from fridge magnets or cars starting.
    It doesn't have to be MuMetal - a piece of steel will provide provide serious magnetic field shielding.
    Maybe just reducing the sensitivity - a small magnet so close to the sensor creates a huge Magnetic field.
    Apr 2011
    The Pale Blue Dot
    Quote Originally Posted by MikeAusC View Post
    That's what I thought as well...
    "Mil-spec" is as much a buzz word as "tactical" in a marketing department.
    -Trevor
    "We canít just go with MBAV because itís out there and battle-proven." - Fred Coppola, deputy project manager for Soldier Protection and Individual Equipment
    Apr 2011
    The Pale Blue Dot
    Seems like quite a few threads on the more or less same topic, I am bumping this up. Can we continue here?
    Thanks.
    Flashaholic* 1 what's Avatar
    Jul 2007
    Australia
    You might be interested in:
    http://www.candlepowerforums.com/vb/...buse-by-1-what
    I would have liked to leave it in the microwave longer but didn't want to risk blowing up thr oven.....they don't like operating without a load..
    I still have that flashlight and it still works!
    Apr 2011
    The Pale Blue Dot
    Quote Originally Posted by 1 what View Post
    Excellent videos! About the microwave oven operating without a load, you could stuff a flashlight into the turkey come next thanksgiving...
    This is great stuff ! It's all I needed to know the microwave test in posted link answered all my questions. I think that if flashlight can easily withstand such abuse it could easily survive an EMP !
    In response to the OP's question - there's a visible flickering in low mode of a current-regulated flashlight (Fenix LD01 R4) when it's placed few centimeters from a GSM cell phone during a text message transmission.
    I'm not an expert on RF so I'm not sure if this is a normal occurence for a flashlight. So far I've witnessed only usual side effects of GSM transmission on PC loudspeakers and some CRT displays.
    Cheers
