Klarus
Page 11 of 48 FirstFirst ... 45678910111213141516171821 ... LastLast
Results 301 to 330 of 1432
Thread: ZebraLight H502 XM-L
  1. #301
    Flashaholic* B0wz3r's Avatar
    Sep 2009
    San Francisco Bay Area
    Default Re: ZebraLight H502 XM-L
    Quote Originally Posted by Beacon of Light View Post
    Does anyone know if any new Zebralights are debuting at SHOT going on now?
    Guess we're just going to have to wait and see. I'm not in a hurry as I won't be doing much in the way of camping or the like until spring comes anyway.
    What? Me? Derail a thread?
  2. #302
    Now I'm kinda worried. I haven't seen a single flashlight/headlamp that runs the XM-L emitter on a single 1.5/1.2V source that has good runtimes at lower levels (equal to or higher than XP-G). I hope this isn't a problem for the H502.
  3. #303
    Flashaholic Surnia's Avatar
    Jan 2010
    Ontario, Canada
    I know they have the XM-L slated for the H502, but I'm wondering if this will limit the possibility for a H502c?
    My tiny collection
    Zebralight: SC5 OP, H502d || NiteCore: D10 R2 Tribute || JetBeam: RRT-0 XM-L || L3 Illumination: L10 Nichia 219
  4. #304
    Sep 2006
    Ukraine, Odesa
    ZebraLight, are you read this topic ? 8-) What you can say about H502w release ?
  5. #305
    Sep 2009
    Quote Originally Posted by js82 View Post
    I just checked on the Spark ST5's, the 190nw and the 180ow, which use a T5 XML and an R4 XPG respectively, and they're almost exactly identical in run time and output.
    190nw 180ow
    190L / 0.9h 180L / 0.9h
    100L / 1.8h 100L / 1.8h
    36L / 8h 36L / 8h
    10L / 30h 10L / 30h
    2L / 86h 2L / 86h
    The only difference is the slightly higher output on max of the 190.
    I don't have an 180 to compare to my 190, but I imagine the 180 has a tighter hotspot and a bit more throw than the 190. For me it doesn't matter, as I always use the frosted lens in mine anyway.
  6. #306
    Sep 2006
    Ukraine, Odesa
    You may open datasheets - minimal differences between these LEDs , when it works low -middle power, XM-L works more efficient on 200 lm and higher.
    But spectr of neutral white XM-L looks slightly better, than neutral XP-G.
    And Zebralight say, that new dc-dc driver will work better.
  7. #307
    Sep 2009
    Quote Originally Posted by evgeniy View Post
    You're missing the point. The question was whether or not the XML is as efficient at lower outputs as the XPG. Using the example of the two Spark lights above, it is. The question was not about efficiency at high outputs, but efficiency at low outputs.
    There may be other lights that don't show this equivalence, but that would be a driver issue. Yes, spec sheets could provide some insight, but since when as ANY emitter ever performed exactly as indicated by the spec sheet? Circuit design, heat sinking, etc. all play important roles in the efficiency of an emitter.
    Your reference to spec sheets is a class example of engineering getting lost in the numbers and not paying attention to real world factors that affect performance. Engineers are always trying to build a better mousetrap, but in the process, they get lost and forget that what they're designing may be possible from an engineering standpoint, but is impossible to make, or once it is made actually doesn't work because the engineering demands require the entry to the mousetrap be behind some other part of the trap, therefore making the better mousetrap completely useless.
  8. #308
    Quote Originally Posted by B0wz3r View Post
    190nw 180ow
    36L / 8h 36L / 8h
    10L / 30h 10L / 30h
    2L / 86h 2L / 86h
    I don't have an 180 to compare to my 190.
    c'mon Professor. he relied on CREE's specs sheets for his post. you relied on Spark's marketing specs for yours. same difference. since you haven't compared a 180ow and a 190nw side by side, it's just theory for you too.
    and by the way, you weren't even in disagreement about the low current performance of the XML vs XPG. you both seem to think performance should be about the same
  9. #309
    Sep 2009
    Quote Originally Posted by robostudent5000 View Post
    Ah, it's all just... technicalities!
    I've got plenty of other lights that have XPG's in them... I'm just too lazy to get them out and do a side by side...
    In the end though, I think the moral of the story here is that it's different tools for different purposes. What's the old saying? When the only thing you've got is a hammer, everything looks like a nail? If you want something that's a marathon runner, get a vampire light. If you want something that's a burner, get a big gun. That's what I love about my Zebras... they can do both!
  10. #310
    that's not the moral of the story.
    the question was whether the H502 with the XML will be as efficient at lower outputs on a single AA as Zebra's current 1xAA models are that use the XPG. different tool for different purposes was not the question. it was efficiency at low outputs for XML vs. XPG.
    see?
    efficiency at low output comparisons between two emitters is independent of use considerations since what you use them for doesn't effect how well different emitters run at let's say 20mA. we're not talking about beam shape or tint or throw or anything else that matters when different uses are being debated. efficiency at low output is efficiency at low output regardless of your use.
    the real moral of the story is that if you tell someone that they're "missing the point" when in fact they're saying pretty much the same thing you're saying using references that are at about the same level of authority as the ones that you used, you run the risk of having that pointed out by even the lowliest of students like me.
    and in case you thought that your point and evgeniy's point were different, here's evgeniy's post again.
    "minimal differences between these LEDs, when it works low-middle power" that's pretty much what you said.
    "XM-L works more efficient on 200 lm and higher." you mentioned something similar as well.
    here's what you wrote again.
    you said he was "missing the point":
    but i don't really see that.
    he said "minimal difference" up to mid output, you said "almost exactly identical" except for max, pretty much the same point
    he said "more efficient on 200 lm and higher", you said "slightly higher output on max of the 190", pretty much the same point
    see?
    and as i mentioned earlier, he used Cree data sheets as his basis and you used Spark tech specs, which are probably about the same in terms of authority on this particular topic.
  11. #311
    That's really my question. Thank you for stating it clearly and completely. I failed to mentioned in my post that I want to compare it to zebra's very efficient AA XP-G lights.
  12. #312
    Nov 2009
    Canberra, Australia
    Seeing as none of these ZL lights are being direct driven it may well be the relative efficiencies of the drivers that makes more difference to run times at lower levels, not the difference in efficiency of the emitters. Given that they are made by ZL who are known for excellent driver efficiency but continually try to improve I hope that the H502 will be even more efficient than their existing single AA lights.
    Testing once they are available will give a more definitive answer to the question, until then it is all speculation.
    WTB Any Brand locking pliers multitool, Kershaw Bit Kit, leather sheath
  13. #313
    Sep 2006
    Ukraine, Odesa
    "XM-L Color Separation"
    http://www.candlepowerforums.com/vb/...lor-Separation
    "All of the XM-L samples I have tested have the color separation over the viewing axis. "
    If it's true - maybe, H502 / 602 with lens (instead on reflector) + XM-L isn't a good idea ?
  14. #314
    H502/H602 should be fine. reflectors, especially smooth reflectors, amplify this effect. effect should be minimal, probably unnoticeable, with just a plano convex lens.
  15. #315
    Flashaholic ryguy24000's Avatar
    Mar 2011
    PNW
    WFT is a 602? Another imaginary light to be released in Q4 of this year? Kill this thread already!
  16. #316
    Flashaholic* psychbeat's Avatar
    Nov 2009
    SF norcal
    Default
    The 602 is the cold fusion nano tech model made for spotting Chem trails and shadow people.
  17. #317
    Flashaholic* csshih's Avatar
    Sep 2008
    San Jose, CA
    Quote Originally Posted by psychbeat View Post
    Just Because You're Paranoid, Doesn't Mean They're Not Out to Get You
    Craig
  18. #318
    Sep 2009
    I'm going to hold off on a new headlamp for now. I'd love to have an H51fc, but I'm going to wait either for a 501c, or a 502w or 502c.
  19. #319
    *Flashaholic* pjandyho's Avatar
    Oct 2003
    Singapore
    I am so addicted to the "c" version I felt inclined to wait for the H502c but I don't think there is any form of high CRI XM-L emitters in the market yet. Not sure if we will get to see one soon.
    The love of light is the reason why I don't walk in darkness. But darkness has it's beauty...Sadly, my lights are much more beautiful!!
    Beam shots Night Trekking with HDS high CRI and McGizmo Haiku & Mule high CRI
  20. #320
    Sep 2009
    Quote Originally Posted by pjandyho View Post
    Hopefully they will do one... if not, there's always the XPG and the Rebel they could use instead. I wouldn't not buy one if it had a Rebel instead of an XPG or XML.
  21. #321
    Flashaholic nuggett's Avatar
    Oct 2005
    NC
    Just thought I would chime in here. Been a ZB fan for a long time,own many, but they lost it dropping the pure flood for the reflectors and now delayed delivery for the 502 and 602. going Spark now.
  22. #322
    you'll be back, wait and see.
    Quote Originally Posted by nuggett View Post
  23. #323
    Flashaholic* Brasso's Avatar
    Jan 2005
    Alabama
    There aren't any high CRI xmls out yet, but the neutrals look pretty good. I have a Quark with their neutral xml in it and it doesn't seem to have any purple/yellow thing going on in the beam. Some people say it's a bit yellow/green, but I like it.
  24. #324
    A&Q Moderator
    Woods Walker's Avatar
    Jun 2008
    New England woods.
    Darn it doesn't sound good. On the up side I get to keep a bit of cash in my pocket.
  25. #325
    Are they still celebrating Chinese New Year or something? First quarter of 2012 is here and still no H502.
    EDC: ZL H52w, H502w
    The only useful tool is the one you have with you when you need it.
  26. #326
    CNY was more than a month ago. Maybe they encountered some of the technical problems that were mentioned in this thread.
  27. #327
    sigh, holding out for the 502, but can't wait for long.
    Anyone know shipping times to Australia?
  28. #328
    Flashaholic* Samy's Avatar
    May 2011
    Australia
    Default
    It's about 16-20 days if you order direct from zebralight. It's about 8-10 days from going gear.
  29. #329
    Quote Originally Posted by davidt1 View Post
    They're punishing you for sabotaging the Zebralight Mods thread. The lesson is, "Never deliberately mess with the content of a stickied reference thread."
    And hey, first quarter ain't over yet. I'd like to see the H502, too, but I'm not going to agonize over the release date. The release will happen when it happens -- and that's probably regardless of how much we complain about it here.
  30. #330
    Sep 2009
    At this point I think I'll probably just get an H51Fc as my next headlamp. Or if Spark comes out with a HCRI version of one of their all flood models.
