Hi All
Looking for a true 5500 or 6000 MaH 3.7 volt Li-On. Protected. Ideally 6000 MaH at 0c. That stays close to 3.7v until capacity close to exhausted and then rapidly drops. Good to high quality. With tabs (or capable of taking tabs). So looking fir nirvana, but will settle for bliss.
Almost bought an AGM Battery,but price is now $150 per cell!!! Ouch!!
Goal: to assemble into a 4 pack, in series and parallel, to get 12000 MaH and 7.4 volts. Must fit into a cylinder that that us a tad wider than 32600s. I will post cylinder size. It readily fits 4 standard D bats, and with an insert can fit 5 standard C bats. There is sufficien play (in diameter and length) to fit a pack. Wish to set up the pack so that it is not wired, but is an insert that will fit between the contact springs at the + and - poles.
LED array has max 8.4 volts.
Would appreciate any help re sources for the bats and design of the pack.
Thanks
Jhcolman
Thanks
Jhcolman
