gcbryan
I think I've come to a few conclusions regarding headlamps as I use them/am interested in them. They are convenient around the house/yard of course but my interest in them is mainly in their use for hiking/camping.
Some are spot with a diffuser option, some are a combo (in one beam) and some are spot and flood (two beams). Then there are the dedicated flood only (Zebralight). For the multi-purpose types however like Petzl, BD, PT the flood options really are useless except around camp and in the tent. The red LED function is even more limited as most are very dim.
So although some may have more "bells and whistles" than others what it really comes down to is the "power" emitter and except for the lights like Zebralight none of the multi-purpose lights use power emitters for the flood function and that's why flood is not that useful in these lights.
I've had the BD Spot. I have the BD Storm and I was looking at the PT Eos and I've looked at the Petzl Tikka XP 2 in the past. Even though the Storm has more bells and whistles than the Eos they are essentially the same. All I really use is the spot beam which I've put a piece of translucent tape over and this is more or less the same as the Eos.
The XP 2 is interesting in one way. At least when the diffuser is used the emitter is the efficient one rather than a 5mm or SMT emitter which all the rest of them use.
I've also noticed that 60 lumens is about where I use my light most of the time even though it's infinitely adjustable from 100 lumens to 4 lumens (this is when hiking) If it's just a trail not in the mountains I may use at 30 lumens. Those also just happen to be the two settings on the XP 2 and 60 lumens is close to the upper end for the Eos as well (70).
I have the option of 100 lumens on my headlamp but it's more a pain than anything else because I always have to adjust it down. If max was 75 lumens it would actually be better.
I see that the Eos is available in some places for $35 or less (although with tax in some cases and high shipping it's a lot more) . It's waterproof and regulated. It might be the best light out there just because they kept it simple. An Eos with a built-in diffuser (similar to the XP 2) might be perfect especially if it came on in low first!
I'll probably not get the Eos just because mine does what it does (and more) but I don't really need that "more" most of the time.
They (Eos) didn't keep adding features to the point where they messed up and made the light undesirable in some aspect like Petzl ended up doing with the XP2 even though I like the build-in diffuser concept. Plus the XP 2 is $55 vs Eos $35...they should be the same.
So I'll just keep on using mine in diffused spot mode only I guess until someone actually puts all the pieces together a little better. If I decide to get a second or backup headlamp anytime soon I'm sure it will be the Eos while I wait for the next round of "improvements"
Actually the Eox would be an improvement in a way over the Storm because it would always come on in spot mode
Just some observations. Comment if you wish I went on a hike tonight and also finished up a little work after dark in the yard and came to these conclusions.
