UberLumens
- Joined
- Feb 24, 2010
- Messages
- 143
A filter is 1/2 the issue, but as you mentioned a full clean is not possible. So a mix of the two is required.
Quick 1 2 3:
Treat the cause:
1. Clear any large/major causes of dirt in the air as best you can, even if its just a dusting or quick once over, the worst parts are what you need to hit.
Purge the poison:
2. Get a hepa filter system, anything that is real hepa with a few extra filters. Run it hard for a while and change the filters when needed. (This is your "purge", you will eat a filter or two. Once complete the dirty air will be in pretty good shape as you have removed the bulk of it, and the major causes of it(step 1))
Maintain the balance:
3. Put in a fresh filter and change as directed.(normal use begins)
Quick 1 2 3:
Treat the cause:
Purge the poison:
