NIMH were 2000 mah.
The alkaline line looks a little weird because of the large gaps of times between measurements (I have a cheap light meter that I have to manually check, which doesn't happen during the work day).
I don't really see a performance advantage to using NIMH over alkaline in this particular device. I expect that an alkaline low run would have a similar curve to the NIMH but last longer (2800 mah vs 2000 for NIMH) because the alklaline run is already pretty flat.
