Miboxer
Results 1 to 9 of 9
Thread: GPS for iPhone use data plan?
    Nov 2007
    California, Los Angeles
    Question GPS for iPhone use data plan?
    Hello,
    I am planning to get Magellan Roadmate for my iphone. I want to know if I use the gps function (pre-loaded maps) on my iphone, does it charge me for using data? I don't have a data plan. I read on the web with mixed answers. I know you guys/gals are a smart bunch. I hope you can answer this for me. TIA
    DG
    Default Re: GPS for iPhone use data plan?
    You have to check the software. It depends on what type of iPhone you have. The only navigation app I know of that doesn't use data if your iPhone has built-in GPS (that is 3G and beyond, IIRC) is Tom-Tom for the iPhone.
    Default
    Quote Originally Posted by dealgrabber2002 View Post
    Hello,
    DG
    Navigon works even if you don't have any cellular signal -- takes a little longer to get initial satellite lock without using cell towers to triangulate, but it works. It's expensive for an app ($59), but it has completely replaced my Garmin Nuvi 360.
    Nov 2007
    Quote Originally Posted by flashflood View Post
    I have a iphone 3g using T-Mobile. I have roaming data turned off and I have no data plan. I tried using Navigon and it seems to work okay... did I get charged data?
    edit: I read it takes a few kb to get a initial satellite lock, but after that it uses the map it was pre-loaded into the iphone. Is that true?
    Not according to this: http://tech.kateva.org/2010/08/navig...my-review.html
    I have successfully used Navigon in places where there is no cellular signal at all, like Death Valley.
    Nov 2007
    Thanks. Really appreciate the info.
    Banned
    Jun 2007
    Toronto, Canada
    iPhones 3G and newer all have A-GPS support, so it will use data from time to time unless you can deactivate A-GPS.
    Quote Originally Posted by daimleramg View Post
    A-GPS is just an accelerator for initial satellite lock. If the phone can triangulate from cell towers, it will; otherwise it will use 100% GPS and just take a little longer to initialize.
    *Flashaholic* carrot's Avatar
    Dec 2005
    New York City
    Don't forget that with iOS 4 you can disable the usage of cellular data in the Settings app, so if you need to be certain you are not using up data you can flip the switch.
    [gearcarrot.com] Collector and distributor of (mis)information.
    The Guide to High-End Lights | Flashlight Story Collection updated Sept 28
    CPF Specials | 4sevens | LED Testing | EDCF | #cpf
