Based on the recommendations that I read here, I bought a Mozo Ultralight 35W about a month ago. On it's first use, I ran the light for ~10 minutes with no problems. The light was not handled roughly and was not dropped or knocked around. Immediately after that first use, the HID bulb no longer lights (LED strip is working fine). When I flip the switch to HID mode, the light emits a buzzing or low humming noise, but the bulb emits no light.
The battery is fully charged and I've confirmed 12V from the battery with a multimeter. Hooking the bulb leads up to the multimeter indicate a broken circuit, which I believe is right since the circuit would be completed by an arc through the gas reservoir in the bulb.
Since the battery appears to be functioning correctly, I'm guessing that the problem is either with the bulb or the ballast. As a first time HID user, I'm unsure how to function test both of these components independently.
Any help or troubleshooting tips would be appreciated.
