Is there a DIY on this? I'd like to build a pack that's protected from unprotected Li-Ion cells. Can I use just one PCB to protect all the cells or does each need it's own?
if you buy shink tubing from all-battery, remember their sizes are not diameter, they're flat accross
pads on the board for P (power) are connected to the charging connection, and B (battery) to the battery connections.
i've seen a cheap-o four cell 18650 battery box with some sort of cheap charge balancing built-in for $15 (just thinking built-in BCM'd be nice, but guessing it's configured with 2P 2S) that's built to output 5 volts.
