flashmenow
Hi all. I have a question regarding RCR123 and rapid discharge.
This is how the story goes. I have a 1 cell Vital Gear body LEGO. This atm has a XM-L drop in. My thoughts are to install a SST-50 drop in.
So the question is, will running a SST-50 on a RCR123 create a danger rapidly discharging the single cell ? Other then shortening the life span of the battery are there other dangers ?
I fully understand run times will be very short. This build idea would be for momentary use, and or limited use/run time.
Sorry if this question was posed before the search feature was not much help. Thanks Glenn
This is the LEGO in question, and I have a CRYOs cooling bezel for it inbound to deal with the projected heat issues .
Thanks for the read and any input. Glenn
