Results 1 to 5 of 5
Thread: XP-G on a XP-E board works??
    Flashaholic* skyfire's Avatar
    Dec 2009
    Los Angeles
    Default XP-G on a XP-E board works??
    im looking to buy some 14mm XP-G boards. but cant find any... I have found XP-E 14mm boards though.
    does anybody know if XP-G emitters will work with XP-E boards?
    thanks
    Default Re: XP-G on a XP-E board works??
    have a looker at the datasheets to compare dimensions
    May 2007
    Greece/Hellas/Crete
    You can use a pcb for xp-e with an xp-g led.
    I modded my fenix E21 that has a xp-e R2.
    Removed the (glued) head with some difficulty, then removed the pcb with the xp-e, removed the led, reflowed an xp-g, and now i have a nice neutral xp-g R4 flashlight! Like LD25!
    Dec 2009
    Los Angeles
    thanks for all the responses...
    the XP-G and XP-E looks to be the same dimensions and everything, just wanted to comfirm that its ok to do.
    deadrx7conv, thanks for the link... ill probably get some of those.
    btw, i love mazda rotaries... i used to have a turboII. and a rx3, but sold it before i could finish restoring it... a regretable mistake.
