ArmyTek
Results 1 to 3 of 3
Thread: Projection TV Lens's
    FRITZHID's Avatar
    Jun 2011
    Icelandic wastelands of Monico, WI
    Help Projection TV Lens's
    i have managed to acquire 3 rear projection TV lens's, from a CRT type tv. these have 3 total lens' inside the housings. 1 main middle convex lens and 2 what look like fisheye lenses, (1 on each end), then there was a liquid lens mounted directly to the CRTs themselves but that lens was left behind for obvious reasons. Anyone here know a way to use these loose lens' in a spotlight effectively?
    any and all advice would be welcome as i have not worked with lens's at all as far as spotlights go.
    Flashaholic* Sway's Avatar
    Aug 2003
    North Carolina
    Default Re: Projection TV Lens's
    something close that may give you a few ideas
    http://www.candlepowerforums.com/vb/...made-spotlight
    Lucas Jackson, "Here, Captain"
    Maliciously destroying municipal property while under the influence, What was that?
    "Cutting the heads off parking meters, Captain."
    FRITZHID's Avatar
    Jun 2011
    thank you Sway, that thread gave me some practical info to be sure! i may go LED but i think i want to try a HID 1st. been having too much fun with my Stanley & my 100w MH tinfoil hack job. the only thing i'm not looking forward to is the fact that i'm probably going to need a polyelispoid reflector. but thats part of the fun too! thanks again Sway!
