samgab
I'm wondering if there is there a fairly scientific way to test a battery's capacity, in Mah, without using any fancy equipment, like one of those chargers that will discharge at a set rate and give a result.
I have battery's such as 4 new NiMh D cells that claim to be 9000 Mah each, and I'd like to test them all and see how many Mah's they actually have.
I have a multimeter, but that's about all.
I could run them in a flashlight until they run out and time it,
but how would I work out the capacity...
What is the formula? And it would have to be a lamp without any electronic gizmos to maintain output.
I guess I could get a 1.2-1.5 volt bulb, with XX wattage, check the current when connected to the battery, time the runtime till it runs flat, and then use whatever the formula is? or is there an easier way?
Thanks!
Thanks!
