Hey, first post. I've been doing plenty of reading but I'm still not clear on what I should buy so I'm just wondering if anyone will kindly give me a shove in the right direction. (There's already quite a few threads on this, but not really anything helpful in the last 3 or 4 months, and technology moves on)
TL;DR:
I'm looking for something which will allow me to comfortably/safely ride along lit and unlit sections of sealed road and bike paths at 30-35 km/h (~20 mi/h) without fear of unseen pot holes, fallen branches, broken glass or other rubbish. This equates to being able to clearly identify small objects coming towards me at this speed from 50+m (yards) away until point blank.
I'm looking for 2+ hours run time on a single load of batteries, but intend to carry 1 or 2 spares. I'm happy to go with whatever as far as batteries are concerned (looking at 18650 atm), though I already have a AA/AAA NiMH charger.
I also need to be able to take the light with me to prevent theft so quick and easy installation (<5s) and removal (<2s) is good (there's already plenty of ideas around on mounting though).
Lastly I'm looking to get the whole shebang including batteries and all on a Uni-Student's budget of $80 Aus. (For reference, 1 AUD = 1.07 USD at the moment)
Ordinarily I'd have no hesitation about ordering the bits and doing a DIY job, but by the time I buy a decent multimeter, soldering iron, solder etc. I'll have already blown my budget well and truly, without starting on the light.
I'll be using the light on my way to rowing training in the mornings (About 30min ), and for getting home again at night from uni or wherever I am (potentially up to 1 hour depending on traffic). I could get by on anything down to 90 minutes run time, but I don't want to have to deep cycle my batteries all the time and if get held up for whatever reason (flat tyre) I don't want my lights to die before I make it home.
I'm not really concerned about tint and holes, just as long as it's not pure blue or something as I'm doing this on a tight budget and I only need to see (and be seen).
Options so far:
If I go 18650;
Charger: $11 - 3.7V Li-ion Charger (individual charging channels)
Batteries: $10 - 2x18650 2400mAh 3.7V Protected
Mount: $0 - Hose clamps and inner tube
Leaves me $60 for the torch.
A multi mode XM-L T6 or U2 driven at 2.5A-3.0A H, 1.2A M, <1A L seems to be the way to go (low thermal resistance, 900L at 3A, 125° spread, high efficacy (claimed 100L/W at 1000L)), probably with an OP reflector for spill. The SST-50 seems a good second choice.
I don' particularly like the Majic Shines because of the endless QC issues, and the external battery pack would be fiddly to remove/install.
Likewise with other really cheap Chinese lights.
I'm in two minds about a P-60 host + drop in, because although they get solid reviews I'd like to be able to use it without any fear of overheating. (Did I wrap the foil well enough? Is my money going to go up in smoke if I try a runtime test on high?)
With all that in mind what would you recommend?
Thanks for any help you're willing tio give me. Considering how much time it's taken so far I'll be sure to do a proper review of whatever I end up purchasing, as I'm sure it'll help plenty of others.
Cheers,
Mazrim
Some extra but not particularly relevant info:
TL;DR:
Options so far:
If I go 18650;
Cheers,
Mazrim
Code:
For all the web pages I've read through, there's never really been any quantitative
discussion. It seems to be all along the lines of "really good light, super bright,
great for riding, plenty of battery life" without any explanation of the usage
scenario. I've done my best not to do that here, to help you help me. ;)
Another point which makes it difficult is I have no real world comprehension of
how many lumens I'll need for what I want to achieve. For the benefit of anyone
else in the same boat, from what I've read I believe I should be aiming for
around 400-500 actual LED Lumens.
Battery life from a single 18650 looks like it could fall a bit short, but most of
the cheap Chinese multiple 18650 lights just use an extender tube and mount
them in series which would make sturdy mounting far more difficult, especially
when it's an aluminium road bike (harsh rides 'r' us).
There are a few 2x18650 side by sides on the market but they all seem to be
well outside my budget, and due to their shape, difficult to mount.
If I could manage a bar light cheaper, obviously that'd be great and might allow
me to get a tightly focused helmet light, with all the obvious benefits this
setup would provide. But a cheap light isn't good value if it doesn't work.
