Life+Gear
400 Lumen LED Flashlight with Flasher
2-pack
CREE™ LED Bulb
Law Enforcement Grade
Waterproof
Item # 580615
Limited Time Offer:
$30 discount is reflected in the price. Valid for orders placed July 25, 2011 through August 14, 2011.
While supplies last.
Online price $119.99 Less -$30.00 YOUR COST $89.99
Introducing the all-new Life+Gear model 400. This is the latest refinement from Life+Gear on its popular high quality, aircraft grade hardened aluminum flashlights. These lights are some of Costco member’s most popular tactical high-end flashlights and all for an extreme value vs. other flashlights of similar quality.
Life Gear’s new model 400 also incorporates a new-patented “See and Be Seen” technology that includes a separate switch that activates an LED flasher at the base of the flashlight shaft. This, in combination with a new high-tech CREE™ LED 400 lumen bulb make this an incredible offer.
Features:
- Aircraft Grade Hardened Aluminum Body
- LED Aluminum Torch
- Waterproof: IPX7
- Polycarbonate Optical Reflector
- 400 Lumens
- CREE™ Super Efficient Bulb
- 4-Mode Electronic Switch: High, Low, Strobe and Off
- New Emergency Red Flasher With Separate Integrated Switch
- Law Enforcement Grade Quality
- 3 x C Batteries (not included)
- Patent Pending Technologies
*400 lumens as per LED manufacturer’s specifications depending on usage style. Lumen output and battery run times may vary depending on mode and use.
[Model LG511]
