Aug 9, 2011 #2 J jorgen Enlightened Joined Oct 31, 2010 Messages 325 I believe, i read, they function as a single level light. However,removing the qtc pill completely, in some models, requires modifications.
Aug 10, 2011 #3 Death's Head Enlightened Joined Jun 27, 2006 Messages 305 Hopefully, it'll take years before the pills wears out.
Aug 12, 2011 #4 B Bronco Enlightened Joined Dec 3, 2003 Messages 499 Location Los Angeles I asked this question several months back and IIRC, Curt chimed in to say that the light will continue to function when the pill disintegrates in a single level mode.
Aug 12, 2011 #5 gunga Flashaholic Joined Nov 29, 2006 Messages 8,080 Location Vancouver, BC, Canada Yep, if the QTC wears out, the metal in the pill contacts the other side of the pill = single level (high only).
Aug 12, 2011 #6 L Lord Bear Enlightened Joined Nov 2, 2009 Messages 250 So the actual QTC material is inside the nickel looking disc? (Which has a whitish plastic ring surrounding it to support the sponge/rubber washer?)
Aug 13, 2011 #7 Death's Head Enlightened Joined Jun 27, 2006 Messages 305 Lord Bear said: So the actual QTC material is inside the nickel looking disc? (Which has a whitish plastic ring surrounding it to support the sponge/rubber washer?) Click to expand... That's correct.
