Zebralight Spark Princeton Inova Petzl Maglite Bushnell 4 XM-L MagMod and a lot of Cree XM-L Lights Nitecore i4 Intellicharger Intl-outdoor 3400 Panasonic 3100 Bare and protected Samsung 3000 Sanyo 2600
Please, respect the planet, dont kill animals...
Just received my Gen 2 Intellicharger from goinggear and it does have the new canary yellow sticker as peterharvey pointed out. I'm currently charging some 18650's in it right now.
My dog ate my flashlight...
Still waiting on mine. In the mean time I am trying to charge up for new eagletac 18650s with a single bay charger so I can try out my new TM11. Working 12 hour shifts isn't making that to easy. PURE TORTURE I TELL YA!!!
Just received mine from bugoutgearusa I will test it tonight.
http://img.tapatalk.com/be79ef9a-8fa7-5638.jpg
http://img.tapatalk.com/be79ef9a-8fbe-0db1.jpg
Your images are huge they have been replaced with a links
See Rule #3 If you post an image in your post, please downsize the image to no larger than 800 x 800 pixels. - Norm
Got mine around a week ago. So far its been working perfectly(knock on wood), I've only simultaneously charged 1x 18650, and 2x 16340's.
Yup, charged up four (4) Eagletac 3100 18650 batteries in it last night and I'm currently charging four (4) AW RCR123 batts in it right now. It's very convenient and I like the individual charging status indicator lights above each battery slot, although I'm not sure what the ending voltage is off the charger. I loaned out my multimeter to a buddy and still haven't gotten it back yet.
I still haven't tried charging up my Eneloops in the intellicharger, but I'm impressed with the flexibility and capability to handle four (4) batts a time. Plus, it was half the price of my Pila.
EDIT: Just out of curiosity, I just charged an AW 18650, AW RCR123, AW14500 and an AW10440 all at the same time and it seemed to work without a hitch. Now, that's something I've never been able to do all at once, especially on one charger.
You guessed it draven451!And what a pleasant surprise it was when I turned the TM11 on Turbo
I ordered one from Amazon UK for Ł20 , before i saw this post
So i emailed the company "fireflyextreme" and told them about the problems with the v1 of this charger with a link to this thread and asked if my charger was a v1 or v2, below is the reply.
John.
------------- Begin message -------------
John,
Yes this is the new version. I did have problems with some of the original batch and have been waiting quite a while for the new version, a batch of which arrived yesterday. They are actually branded as 'Nitecore' not 'JETBeam' but they are both made by Sysmax, they probably manufactured the Nitecore branded ones first as that is their 'premium' branding. We are official distributors and our products come direct from the factory.
Regards,
Kevin
Intellicharge i4 - LaCrosse BC-900 - MaHa C9000 - Charge Manager 2010 - Vanson Speedy Box - Accumanger 20 -Thunder AC6
Solar - GoalZero Nomad 7 + Guide10 - Powerfilm USB+AA Solar Charger
I just wondering if I can charge different chemistry batteries at same time. 2 AA and 2 18650?
SFMI4UT
Hi guys, I will like to leave the same question here that I leave in the cpfmp, I am wondering about this, take it from the manual received in the box and the previous manual, the v1 had a max charge current of 1000mha but cant charge 4 li-ion at the same time, but charging one or two batteries take less time than The v2. The v2 had a max current charge of 750mha can charge 4 li-ion but take longer to charge 2 bateries than the v1.
I just ask? Is this an improvement?
SFMI4UT
My website with flashlight information: lygte-info.
With: Flashlight reviews and outdoor beamshots, battery and charger tests, DMM guide in English, USB chargers and boxes.
I have the Version one and was disappointed when I first tried to Charge 4 Lions at once. Everything started flashing but with a little on line research I learned of the problem with
the 120 volt feed. I have since tried it with the 12 volt DC feed and it charges 4 Lions fine. While it's a bit of a pain but I have a DC supply on my bench and that's the way I use it.
Just my $0.02
Charging 4 sony 18650 2200mah since yesterday at 7:17pm
SFMI4UT
Yes. 110v took more than 24 hours...
Edit: Next time I will try with a 12v external power supply.
SFMI4UT
I wonder how many folks are honestly keeping a vigil over their 4 cell chargers loaded up with 18650's for 11 plus (or 24??!!) hours.
Something tells me that Rule #1 is being broken frequently by Intellicharge i4 users.
(#1: Don't charge unattended)
Worse, no doubt some|most are sleeping through the process.
Mine arrived tonight and I just loaded it up with four new eagletac 3100s (they are white now?). Currious to see how long a charge takes with four in there.
I just received my charger yesterday. It's first use, last night, was with four new eagletac 3100s. Sorry, I did not test the starting voltage but charge time was just a hair under four hours. The charger did get warm but never approached any temp that would concern me. Same goes for the batteries. I would have to describe the temp shift on them during the charge as "slightly" warm to the touch. First use it did exactly what I wanted it to and appears to have done it well. Now to go pick up some enloopes and give them a try.
