4 Sevens
Page 9 of 12 FirstFirst ... 23456789101112 LastLast
Results 241 to 270 of 354
Thread: JETBeam Intellicharge i4
  1. #241
    Default Re: JETBeam Intellicharge i4
    I probably won't receive my i4 till tomorrow, but does anyone know if the Sysmax Intellicharge i4 uses the ideal CC/CV charging algorithm like a Pila charger???
    If it doesn't, then how is the i4 disadvantaged compared to the Pila charging algorithm?
  2. #242
    Flashaholic* TinderBox (UK)'s Avatar
    Jan 2006
    south shields, england, united kingdom
    Any photo`s of the pcb , is there any temperature sensing ???
    Thanks
    John.
    Intellicharge i4 - LaCrosse BC-900 - MaHa C9000 - Charge Manager 2010 - Vanson Speedy Box - Accumanger 20 -Thunder AC6
    Solar - GoalZero Nomad 7 + Guide10 - Powerfilm USB+AA Solar Charger
  3. #243
    Enlightened raphaello's Avatar
    Mar 2011
    Bulgaria, Europe
    Has anyone charged a RCR123 battery yet?
    According to the specs if you charge one it will receive 750ma - isn't this way too much for a battery with a capacity of 750mah of its own?
  4. #244
    Quote Originally Posted by raphaello View Post
    From what I understand, an acceptable starting charge rate for lithium ion is .5C - 1.0C, with .7C being about ideal. FYI, C basically means the current required to fully charge or discharge the battery in one hour, so 1C for a 750mAh battery is 750mA, and .7C would be 525mA.
    So, while 750mA might be on the high side for an RCR123, I think it should be fine.
  5. #245
    I just checked, AW RCR123 750mAh cells have a max charge rate of 1.5A (2C). Lower quality cells might have a lower max charge rate.
  6. #246
    Flashaholic* Changchung's Avatar
    Oct 2005
    Where the night is too short...
    Default
    Quote Originally Posted by peterharvey73 View Post
    I dont remember where I read it, yes it is...
    SFMI4UT
    Zebralight Spark Princeton Inova Petzl Maglite Bushnell 4 XM-L MagMod and a lot of Cree XM-L Lights Nitecore i4 Intellicharger Intl-outdoor 3400 Panasonic 3100 Bare and protected Samsung 3000 Sanyo 2600
    Please, respect the planet, dont kill animals...
  7. #247
    Quote Originally Posted by Changchung View Post
    SFMI4UT
    Thanks for that.
    I just received mine.
    Apart from the yellow labelling, there is no indication that it is Version 2.
    The box does say that it has CC, CV, and trickle charging...
  8. #248
    Mar 2011
    Bulgaria, Europe
    Thanks for the information. That sounds great as I can now charge all of the batteries I'm currently using (AA, CR123, 18650) with one device
  9. #249
    Oct 2005
    Default
    Thanks for that.
    Hi, after doing a search about were I read this I think that I confused this charger with other that I was looking before I buy this one. Sorry about this
    SFMI4UT
  10. #250
    The Sysmax Intellicharge i4 does have CC, CV and trickle charging.
    It is written on the box, and also on Nitecore and Jetbeam's website eg nitecore.com/goods.php?id=29 and jet-beam.com/links/accessories/i4.aspx ...
  11. #251
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Just because it is on the box, does not necessary make it correct.
    It does not have trickle charging.
  12. #252
    It is not the fastest charger around, for 3100mAh it is nearly 11 hours:
    Hi HKJ
    Is this charging duration consider normal? I have been charging slot 1 & 3 for ET 18650 3100 x 2 for seven hours. I would expect IT to complete within 5 or so... It is kinda let now. Kindly enlighten What is the usual duration base on my trial above?
  13. #253
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Frakymjay View Post
    Hi HKJ
    Yes, this is normal for 3 or 4 batteries. If you only uses slot 1 and 2 you can do it in about 6˝ hour.
  14. #254
    It is advertised/claimed to trickle charge both on the two Jetbeam and Nitecore websites, and on the box.
    HKJ, have you tested it, and found out that there is no trickle charge?
    I did read your Version 1 review, but I don't think I came across any mention about there being no trickle charge?
    Is the trickle charge good? Because the Pila charger has no trickle charge...
  15. #255
    Aug 2010
    Vancouver, BC
    Some will remember the Pila charger marketing materials describing it as a trickle charger, which it most certainly is not.
    I would not purchase a charger that did "trickle" charge li-ion or NiMH cells, the latter because trickle charging can kill cells, the former because trickle charging can kill me.
    Maybe Sysmax copied some of Pila's verbiage.
  16. #256
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Yes.
    On LiIon you do not want trickle charging, on old style NiMH (i.e. non LSD cell), it can be an advantage (Because the battery is always full, when left in the charger), but it is not needed on LSD cell.
    Not directly, I only measured the current levels.
  17. #257
    FYI, my review of the second edition of this charger is now up:
    Sysmax/Nitecore/Jetbeam i4 Intellicharger Review (V2): current/voltage comparisons
    I got 5 hours to fully charge a 2200mAh 18650, so HKJ's report of 6.5 hours for a 3100mAh sounds about right (given most of the charging time is spent in CC mode).
    And I also detected no trickle charge - just a really low uA current once the charging lights went solid (negligible, and not a concern).
    Full list of all my reviews: flashlightreviews.ca. Outdoor 100-yard Beamshots 2011. Latest: CR123A Comparison 2013.
  18. #258
    Jan 2006
    I use a flashlight that uses a single old RCR123A approx 700mah or less, i removed the label so i cannot tell, anyway i always run the flashlight till the low voltage protection circuit kicks in, so i decided to charge it in my v2 i4, I expected the battery to get hot, being charged at an excess of 1C, but i monitored the temperature with an infra-red thermometer and it never went above 22c , so i was very happily surprised.
    John.
  19. #259
    Flashaholic* Solscud007's Avatar
    Apr 2008
    Nyack, NY
    What is the difference between v2 and v1? I got mine from battery junction. How long should 4000mah 26650 take to charge?
    Collecting is not about what you have but rather what you DONT have . . . yet.
    ABTOMAT: "Newer Surefire lights strike me as the result of CNC programmers saying to each other "Hold my beer and watch THIS."
  20. #260
    Quote Originally Posted by TinderBox (UK) View Post
    I use a flashlight that uses a single old RCR123A approx 700mah or less, ... i decided to charge it in my v2 i4, I expected the battery to get hot, being charged at an excess of 1C, but i monitored the temperature with an infra-red thermometer and it never went above 22c , so i was very happily surprised.
    I'm not surprised, as it really isn't 1C.
    As you can see in that graph from my i4 review, on 1xRCR the charger drops out of CC mode in about 3 mins. After that, it is a slow drop off in current. So the average charging current across the ~2 hrs it take is more like something in the mid-300 mAh range (i.e. ~0.5C).
    Note that the above graph is specific for 1xRCR. On 1x18650, I get something very close to the classic CC/CV algorithm. Again see my review for more details.
  21. #261
    Man, that's one funky algorithm..... I wonder what it's criteria is for kicking out of CC? On the 1 RCR it dropped out by 3.8 volts while on the 18650 it dropped out at over 4?
  22. #262
    I didn't buy a car charger lead. Does any body know the polarity of the centre pin ? Is it centre positive?
    Thanks
    During the day when I don't need a torch ... RC is my hobby http://rc.runryder.com/helicopter/gallery/47842/Always on the lookout for McGizmo/Kuku Titanium torches with Trits..
  23. #263
    Oct 2005
    Default
    Quote Originally Posted by mohanjude View Post
    Thanks
    Yes, center is positive... You can find it in ebay for less than 5$
    SFMI4UT
  24. #264
    SFMI4UT
    Thanks
  25. #265
    the old version one works just fine with a 12 volt source
    charges 4 Lion cells - no problem
  26. #266
    Enlightened Sensination's Avatar
    Apr 2012
    London, UK
    Thinking Re: JETBeam Intellicharge i4
    Hi all,
    I new to the community and I got "the sickness"
    Part of it was buying Intellicharger i4, therfore I have a question:
    When one battery is charged, do I have to wait for the others to charge or can I remove it?
    Apologies if this is a stupid question, but I could not find anything via search.
  27. #267
    Aug 2010
    Vancouver, BC
    That doesn't sound like a stupid question at all; the charger has only two independent charge channels. Channels 2 and 4 and 1 and 3 work as a team. If all were fully independent then you'd be able to take out cells at will, but that isn't the case.
    If you have four cells in and remove one, thus potentially affecting what the charger thinks it knows about the other paired bay, what happens to the charge process at the other bay for that channel?
    Maybe ask HJK in his review thread on this charger.
  28. #268
    Apr 2012
    London, UK
    Thanks for the fast response. I will ask HJK
    Jetbeam - PC20, PA10
    Fenix - LD22
    Klarus - XT2C
  29. #269
    Oct 2005
    Default
    24 hours is definitely not within specifications for the charger. I used about 11 hours to charger 4 x 3100mAh batteries.
    What voltage is the 110V exactly? In my test it is 107V and only 50Hz
    Hi HKJ, I just receive 4 panasonic 18650 3100, all comes in 3,16v put all four in the charger at 2:25pm full charged at 8:40pm cutting charge at 4,19v using the 12volts DC connection with a external power supply.
    I check the AC voltaje and is 109v 60hz
    The next time I will use the AC connection to charge all four to test the charge time.
    I think too that the old 4 batteries that I charge the first time had a high internal resistence.
    SFMI4UT
  30. #270
    Were these batts old/used? My understanding was that new Li-on batts would measure around 3.6v when new/before charged up.
