A friend of mine has a Black & Decker light that uses a bulb marked "XPR 24VO .45 AMP JAPAN." It's a PR base, 24 volt bulb (as you can guess from the marking).
He has not been able to find a replacement and both the manual and the local B&D store gave him a parts number that turned out to be an 18 volt lamp. The original bulb is a Krypton, but a Xenon or an LED would be an obvious choice if it were up to me.
I've had no luck finding one either and would appreciate any help. Thank you in advance.
