Carbon scales with titanium liners, tweezers and toothpick. This one is put together like a Sebenza with phosphor bronze washers and the pivot pins of a precise length that the outer liners butt up against so the Torx screws can be torqued down. This leaves the tools in a consistent tension so you don't have to keep playing with the screw tension. The washers are all .005" except one next to the main blade which is .020" to make up for the stamped washer area of the stock aluminum liner.
