I'm a newbie to modding lights and want to attempt my first mod of a 2 d-cell mag. I've read about 15 different mag mod posts on here (including all of ma_sha1's :bow, but still had a few questions.
Here's a quick breakdown of what I want to use:
Host: 2 D-cell Mag (with the T8 torx screw:shakehead)
LED: SST-90 Red http://www.luminus.com/products/datasheets/PDS-001342_Luminus_SST-90, Product Datasheet.pdf
Cooling: SST-90 Heatsink from BriteLumens http://www.britelumens.com/
Batteries: Four 1.2v sub-C 1500mAh NiCd batteries (Using PVC sleeve) http://www.megabatteries.com/item_details2.asp?id=13725&cat_id=226&uid=1430
I plan to direct drive the LED and hope to get around 600 lumens. My questions are:
- Is there a better battery option to run 6A to the LED? The forward voltage listed on the spec sheet is 2.2v.
- Will the stock switch be able to handle 6amps?
- Has anyone used the Mag reflector made by Phoenix Electroform products?
- What is the difference, if any, between the stock reflector (LED version) and the rebel SMO reflector?
- Where can I get a sweet bezel for this thing?
