I decided to start a new thread on this, to carry on from the discussion in http://www.candlepowerforums.com/vb...charged-with-Maha-C9000&p=3347131#post3347131
My 1 year old C9000 (OJxxxx) recently started terminating the charge on slot 1 early, about 80-90mah less than the other slots, no matter which way around I put the cells. The other slots were pretty close. The reputable online shop where I bought it agreed to an exchange, and said they'd seen this a few times.
So I bought a new C9000 (OKxxxxx) to use while getting the first one replaced (which I haven't done yet). The new one consistently charges about 30-40mah less in slot 1, no matter which way around I put the cells.
Has anybody else had this problem and had it fixed? I'm not super happy for it to be considered "normal" it seems like a design fault or manufacturing fault to me. I don't like having to wait for the 2 hour topup charge to finish to know the cells are more evenly charged, sometimes I need to pull them out once DONE appears.
I've been in contact with somebody on another forum who also had a C9000 (unknown batch number), which was charging noticeably less in slot 1. After testing, the same online shop replaced it with an OKxxxxx, but his new one has exactly the same problem, its about 60mah less when charging in slot 1.
I've heard the theory is related to heat, but the other outer slot (slot 4) doesn't have this problem. The only thing I've determined so far is it terminates on max voltage ie 1.48v rather than temp. I know temp can affect the voltage though, so am considering doing a charge with a powerful fan aimed at the cells, to try to keep their temps similar.
Any ideas??? Anybody got a C9000 that charges slot 1 the same or different to the other slots?
The problem only seems to happen for me when the cells need at least 1000-1500mah to be charged in. If its less than 1000mah the difference is minimal.
