jonahailsa
Banned
- Joined
- Oct 8, 2011
- Messages
- 5
Hey guys!
I've been flying for few months and haven't had a single issue until yesterday!
Here's the story:
I bought a new motor (Himax 2000kv) and a separate BEC to power the receiver. I also replaced the aileron servo on the left wing.
Weather: It was rather windy but I've flown in similar condition before without this trouble.
What happened?
When I flew up towards the wind, the plane turned left and crashed on the ground. I couldn't make it turn right, like the ailerons affected it 5-10%.
I attempted this 4-5 times and the same pattern happened, except once I managed to get high up in the air and I could BARELY turn it right, and I saw the ailerons in correct position, still it was not behaving.
Could it be that the wind was just much more than I realized? Because I believe I've flown in such a windy condition without much trouble, at least I could turn left/right as I wanted as long I faced the wind.
After each attempt I carefully looked at everything on the plane, tried to move the ailerons, checked the rudder, etc.. it was all in correct position and moved correctly. The ailerons can pitch a lot so they should have good effect like I've had before.
So.. could a new motor really make the plane behave this way? Was it just the wind? Any tips on what I could check?
And btw, when the plane was in the air I saw the ailerons in "TURN RIGHT" position and it was still going left, so... what the heck? The reason I kept trying again and again was to find out what was causing this, I was so curious cause it should be able to fly stable towards the wind.
Plane: Hobbycool Bixler with all servos replaced with HXT900, motor: Himax 2000kv.
I think the wind was around 4m/s (according to weather stations) and I've flown in a 4m/s before.
I've ruled out: Interference problem, ailerons and I can't believe it was the wind :/
Thanks!
Here's the story:
What happened?
Thanks!
