Xacto
The other day I got a used Surefire 6R together with an original B65 cell.
The light looks nearly new on the outside, but on the inside there are a few dark spots and it smells not that great. The B65 cell still works, but there is some sort of dirt on the contacts and the wrapping is torn in one place.
Now, before I start to simply scrub the interior, I want to check with you (especially the ones that used that type of light/cell), if the dirt could be some sort of residue from the B65 cell. I intend to clean the inside of the battery tube using Isopropyl alcohol.
Could there be any problem just in case the dark spots on the inside come from the B65 cell (Nickel-Cadmium)?
What would you recommend as an cleaning agent?
Any health hazard possible?
If so, I would need to use the weekend and clean the light on the balcony. Since there is a second, near identical light still in sale with the same type of tailcap, I would like to bring mine soon to running order before the auction ends so that I can check if I do like the feel of the older (smooth) tailcap button vs. the older but sort of kurled tailcap button (both times the old ones with the bigger diameter and the loose switch parts).
Thanks for your time and tips, hints, etc.
Cheers
Thorsten
Cheers
Thorsten
