PhotonWrangler
I have a light fixture that uses a pair of bi-axial 55w fluorescent tubes. Yesterday the fixture started to flicker, then it suddenly went out. I opened it up and found that one of the tubes had a tiny hole in the glass wall with a small crack extending from the hole. It looks like it's a double walled tube and the outer hole is 2-1/2mm with a smaller pinhole in the inner wall.
This is not an off-brand lamp; it's a Sylvania FT55DL/841, made in Italy.
I've never seen a fluorescent tube fail this way before. Have you?
