Hi
I'm starting to understand more about flashlights thanks to this forum, but I still have a lot to learn about batteries. I have read some of the threads and graphs on here but to be honest, it can be a bit like taking maths, physics and chemistry lessons all at the same time - and I was never any good at those subjects at school!
Can you please confirm if I have got this right regarding volts and amps:
1. Does a typical AA Alkaline battery (1.5 volts) gradually lose its voltage in use - in other words if it is connected to a bulb without a regulation circuit will its voltage eventually drop to almost zero (so therefore after 50% of its life be delivering 0.75 volts?) Is this the same for NiMh rechargeables and Lithium primaries, or do these types of battery hold their full voltage for longer and then suddenly 'die'?
2. Does the number of amps directly relate to runtime? i.e. if an appliance requires 500 mAh to drive it, will a 500 mAh battery power it for an hour and a 2000 mAh battery drive it for 4 hours? In other words if my flashlight is stated to run at 100 lumens for 1 hour with a 2000 mAh battery, will it deliver the same output for 1.5 hours with a 3000 mAh battery?
