SunwayLED
Results 1 to 13 of 13
Thread: Cordless Home Phone NiMH mystery: help me before I burn my house down
    Aug 2000
    Silicon Valley, CA
    Default Cordless Home Phone NiMH mystery: help me before I burn my house down
    My cordless home phone set is a couple of years old and the batteries are no longer holding a charge. I looked at the batteries and see they are orange Panasonic NiMH AAA, labelled 1.2V min 630mAh. Okay good, I don't need a new phone, I'll get rid of the Panasonics and replace them with some Eneloops, which just lit up the 100% light on my ZTS (sorry, not VM/MM to get exact voltage). So, I put the Eneloops in the phone, and the phone boots up with "Charge for 7h", which is the message when the batteries are nearly completely run down. Weird, I put in new charged batteries and it thinks they're dead? Tried another pair of Eneloops, same thing. So I put it on the charger, and it says it's charging. Batteries are warm but not hot -- though I note some Eneloops I put in the charger are not warm at all. Did I break some weird rule? Why in the world does the phone think my Eneloops are dead if it runs on what appears to be the exact same kind of batteries -- NiMH AAA? Am I risking disaster by putting the phone back on the charger? Obviously, I'm going to keep checking battery temp. Should I just dump the phones and buy new ones?
    *Flashaholic* Mr Happy's Avatar
    Nov 2007
    Southern California
    Default Re: Cell Phone NiMH mystery: help me before I burn my house down
    When you put new batteries in a phone or other device it is normal to give them a long "balancing and forming" charge as this will prolong their life later on. The phone has detected that you put new batteries in it and initiated the new battery routine. There is nothing to worry about; you will need to let the phone do its thing.
    Tiefer, tiefer, irgendwo in der Tiefe gibt es ein Licht
    Aug 2000
    Silicon Valley, CA
    Well that's a relief. I guess I can take off the firefighting equipment. thanks, makes sense
    Flashaholic* 45/70's Avatar
    Oct 2005
    Rural Ohio
    Hi Joe. What I do in situations where the setup "thinks" I've installed new cells, is just go ahead and run the device for a while, without charging it first. In the case of my Panasonic cordless, I can run the phone down until it quits. If the cells are reasonably matched, when the phone actually quits working, the cells are at 1.20/cell, so there is little danger of over discharge/reverse charging occurring, as the "cutoff" voltage is reasonably high.
    Dave
    Flashaholic* TooManyGizmos's Avatar
    Jan 2006
    Humid Florida , USA
    Joe..in your thread title..didn't you mean "cordless" rather than "cell" phone ?
    ~ "She" says ... ... I have ... TooManyGizmos ~
    Aug 2000
    Silicon Valley, CA
    Yes, cordless, not cell!
    Dave, the phone did work, probably could have run it down. Seems to be well into the charge phase now, so all's well that ends well I hope! Thanks
    Joe
    Banned
    Sep 2008
    Spearfish,SD/Williston,ND
    I thought this thread was going to be about using an old suitcase cell phone battery or something.
    Jan 2006
    Humid Florida , USA
    Joe ... could you please change the title to say "Cordless" rather than cell ...
    This is not about a cell phone battery. No need for a misleading title .
    Makes Searching for info in titles much more accurate and usefull .
    Flashaholic* Wrend's Avatar
    Oct 2010
    United States, IL
    I don't trust devices that "think" they know more about batteries than I do.
    If the cells are charged and the phone doesn't think they are then the phone isn't accurately assessing the cells' functional voltage levels and will probably maintain them at an overcharged state which will most likely negatively affect their life potential.
    But hey, most people get their batteries for their electronic devices, not the other way around. And they may last long enough for your needs anyway.
    I'm curious though. If you have a multimeter or voltmeter could you let us know what voltage level the cells are being charged to after they're charged in the phone?
    Never mind; I just reread that bit.
    You don't want the cells to get too hot. So if they start to get very warm near where they start to become uncomfortable to hold, definitely stop charging them.
    Apr 2007
    USA
    Typical NiMh batteries. They never seem to last long, no matter what their use is. Not that lithium ions are any better though.
    ampdude
    Aug 2000
    Silicon Valley, CA
    I actually tried as soon as you pointed it out, but didn't find a way to edit anything but the content rather than thread title.. I assume you know a way to change the title? Happy to make it reflect the actual topic
    Nov 2007
    Southern California
    Quote Originally Posted by Joe Talmadge View Post
    Click the Go Advanced button when editing your post. In Advanced mode you can edit the title.
    Jul 2011
    England
    Post deleted: Mr happy types faster than me
