Dr Evil
I am hoping someone here will help me with what should be a simple project. I don't have any light for the back yard other than a single light by the back door. I took it down and put a floodlight kit in its place for the time being. Here is a quick diagram I came up with. It is not to scale and doesn't have the whole back wall.
Red circles are existing lights. Green circles represent the floodlights I want to put in. One and two represent current switches. Light blue lines are doorways. There is a single 3-way for the dining area light by the 1. There is one 3-way and one normal switch by the 2. Will the list of items below legally work for what I to do?
1. http://www.lowes.com/pd_155250-334-...duct_qty_sales_dollar|1&facetInfo=Combination
2. http://www.lowes.com/pd_163387-334-...duct_qty_sales_dollar|1&facetInfo=Combination
3. A dimmer switch for the floodlights that will mount by the door.
4. A 3-way dimmer switch for the dining area light that will mount by the other doorway.
5. 14/2 wire to run to the floodlights, wire nuts, electrical boxes
I believe item 2 is a single-pole/3-way combo. I know they have such a thing at the store.
Here is what I'd like to do. Have the dining room light run off a 3-way by the back door and a 3-way dimmer by the other doorway. The single-pole would run the light by the back door. Then I would have the dimmer switch by the backdoor for the floodlights. I'd like to use the existing wiring to provide the power from the circuit breaker panel if possible. Can I run a single 14/2 cable to a box in the attic? Then have it branch off using wire-nuts to go to each floodlight? What dimmer switch(es) would you recommend for LEDs? I know the wiring has to be secured in the attic. Where can I find the spacing and attachment method requirements?
Please let me know if I missed something I might need.
P.S. - I'm still looking for some dimmable LED bulbs for the dining room fixture. I have one of these. It is too red though. I'd prefer to find something around 4000k if possible. Any recommendations?
