There is a closed thread that asked the question on uses for powerful bike generators.
I'm no electrical engineer so this is going to be a pretty rough outline, hopefully not requiring any unobtainium.
The design would consist of four dynamos, two in front and two in back, each pair positioned similarly to caliper brakes, alternately the back brakes would be completely replaced by the dynamo pair and the front brakes would remain as dedicated brakes.
Ideally the frame of the bicycle would be packed with sealed capacitors designed to fit the tubing, and there would be controllers to shift current around as needed depending upon what was happening.
Scenarios
-Going fast downhill, only using enough resistance in the rear dynamos to power Bright headlights and rear running lights.
-Going fast downhill and seeing a problem, applying more electrical braking the lights get much brighter, the capacitors charge up and controller drains capacitors to charge batteries.
-Now the bike is slowed, problem averted, can dim the lights back down to regular downhill running brightness and resume speed.
-From a brief stop, a stoplight or going up another hill hill the capacitors could start being dumped back into the dynamos to give a push heading uphill or for quicker acceleration, the controller holding back enough juice to continue steadily charging batteries...
-If slowing the bike down required more and more resistance I'm sure there are ways to just plain dump energy; horns, amplifiers, arc lights, radio transmission, Air Compressor?!
Compressing air, so long as your tank didn't blow up on you might be more efficient than converting to electricity. Other than the air powered car I haven't heard much about it.
For village use of bicycle power generation it seems like there aught to be a way to make a fairly large low tech but precise flywheel, maybe molded in the ground onsite out of concrete, rebar and steel cable, then jacked up and set on it's bearings in line with the earth's rotation, maybe in a containment pit built for it. The bearings and transmission could be the high tech part, the wheel would be slowly spun up and balanced over some time until it was fit for it's operating speed.
People would take turns charging the wheel and keeping it topped off, maybe set it up so that a single person could pedal in some energy while many people could also hook in and pedal together.
Then at peak use times there would be a lot of high load power available, light up the soccer field maybe?
Scenarios
