Hi, I'm new here. This is my first post and the flashlight below is my first high end led light.
I just ordered a Zebralight SC600 which uses the 18650 rechargeable lithium batteries.
I'm reading alot of stuff about how these batteries must be treated just so or you'll have problems.
My intent was to just shove this flashlight into my back pocket so I could whip it out for use quickly. I'll be using it several times everyday mostly on low to medium power.
Also, I read that temperatures of 86 or higher are a no no with 18650's. Since I'm sitting most of the time and the flashlight is in my back pocket it will get rather warm from body heat.
Is this something I should be worried about?
As for charging, supposedly you should never let these batteries get too low. Fine I can live with that. I'll just recharge every day or two.
I also ordered 2 Trustfire 2500 mAh 18650 Protected Lithium Rechargeable Batteries and
a Trustfire TR-001 Lithium Battery Charger.
One will be in the charger while the other is powering the light.
Or is there something wrong with doing it like this?
Some of the things I've been reading seem a little like a pagan ritual to the battery gods.
As I said I'm a beginner at all this and a bit of a cheapskate as well.
A few weeks ago I would have been shocked to contemplate spending $100 for a smallish flashlight. But here I am excited to receive my new Zebralight.
