Note: thread put on MTBR as well so apologies to anybody who uses both forums!
Following on from this thread on MTBR on road friendly light design I'm making a pair of lights for road use. The aim is to put more light on the road and less in the air than with the standard reflectors and optics we use. The way I'm doing this is by using half a reflector with the LED firing down into the parabola, best illustrated by the following diagram from the aforementioned thread:
Each light contains one XM-L and the pair operate together, with a single LFlex in one light driving both lightheads. The lightheads are made from 1.25 inch 16AWG aluminium tubing and are mounted beneath the handlebars to keep out of the way. Battery power comes from 4 * 18650 cells from DX.
After much trial and error here's the donor for the reflectors (my wife's old halogen bike light):
Here are (most of) the parts for the two lightheads
I've kept them as two lights for the sake of extra heatsinking per LED, and yes, for aesthetics! There's an additional heatsink on the bottom of the lighthead with the LFlex. Here's a mock-up of how the internal parts fit inside, although in reality there will not be any overlap of the two L-shaped sections. The LED is mounted on the inside of the main tube, firing down into the reflector.
Here is a further indication of how things fit together:
And finally here as a taster is a beamshot of one of the reflectors on a testbed. First shot is the control, second is the XM-L through a Regina reflector and third is with one of the cut reflectors from this build. Distance to the fence in the background is approximately 17 metres or 55 feet.
Control:
Single Regina reflector:
Single road reflector:
Control:
