As the title ask, now that I have my foundation or daily used flashlights covered.
SWM V10R and ThruNite TN11
I'd like to expand my EDC flashlight rotation with a single CR123A light with a UI of either a rotary output selector or one which will switch outputs by loosening the head.
I'm absolutely not looking for a light which I have to tighten-loosen to change outputs or one that has you go through the entire output range, including the strobe to select the output I'd like to use.
I'm looking at the following, but not sure about the throw/spill, but not looking at a spot or one without a spill;
* Nitecore Infilux
* Jetbeam Raptor RRT-0 S2
* Hetbeam BC10 (not sure if I want a limited hi-lo)
* HDS Rotary
Thanks for the time and suggestions.
* Nitecore Infilux
* HDS Rotary
