NEXTORCH - 300 m long-shot E6
Page 1 of 2 12 LastLast
Results 1 to 30 of 35
Thread: Some IMR (and others) discharge testing...
    Cool Some IMR (and others) discharge testing...
    Just some testing of a variety of readily available IMR cells. I gathered two of each sample that I had for testing. Testing was done at 1C to determine the manufacturer's rating then again at calculated maximum rated discharge (see the summary chart for explanation). Some of the cell didn't live up to their max ratings so they were retested to determine their (subjective) practical maximum. You should be able to extrapolate any current in between my test discharge currents.
    Summary:
    Junsi iCharger 306B w/3.00V cut off + LogView 2.7.4.485 + data tables exported to Excel 2010. I have the full data table available, but figured capacity and voltage were the primary concerns. Note: on the updated graphs where the plot line does not reach the 3.00V x-axis, this is due to the voltage dropping faster than the software's datalog interval of 2 seconds. See the summary chart for the final values as taken off of the iCharger's display.
    Out of four of these 18650 only one was able to perform near rated levels and able to withstand a 15C discharge. My three others performed similar to the blue, red and purple plots above.
    These 26500 are pretty touchy near their somewhat low discharge limit. While @10A their voltage holding looks good and capacity is adequate, @ 12A+ they were unable to hold any voltage and capacity was @10% or worse.
    It looks like I had one bad Shao red wrapped 18350.
    ...artificial cooling used to prevent iCharger cut off on over-temp (50°C)
    And a popular LiCo for comparison…
    And a not so common LiCo...
    On deck: A123 systems 18650 and 26650 LiFePO4...
    If I may generalize, there seems to be better power handling as you go longer vs. wider. I.E. 18650 handled higher current draw better than 26500; the same for 14500 vs. 16340. Additionally, if anyone thinks they will get these types of current draws in lights/devices with the batteries held by spring pressure alone is kidding themselves. I ran my tests multiple times with multiple test rigs and saw HUGE differences between testing with my modded 4Sevens battery cradle (with and without magnets on the cells for contact and 12awg wire connections) and my ratchet clamp setup (w/12awg wire connections).
    -DF
    EDIT: All charts up to date as of 11/2/11
    KineticParadox ...a personal web space with my CBA Battery Testing and my LED Bin Coding Charts.
    Default Re: Some IMR (and others) discharge testing...
    Nice work.
    For the graphs, it might be useful to use a common x-axis for cells with similar capacities. Makes it much easier to compare/contrast. Also, testing at the same current draws for the small cells and the large cells (e.g., 18350 and under for small cells, 17670 and larger for large cells) would also help to make 1-to-1 comparisons. The main question would be which current draws.
    Flashaholic* Battery Guy's Avatar
    Apr 2010
    Portland, Oregon
    DFiorentino
    Really nice work. Thank you for doing this. I have been wanting to test and publish the line of AW cells for awhile now but have not had the time. You inspire me.
    I am quite shocked at the results of the AW 26500 cells. Specifically, they seem to perform quite poorly at 10 A, which is a popular discharge current for many of the hotwire superbulbs that these cells commonly are used to power.
    Might I ask how you made connection to the cells?
    Cheers!
    BG
    Friends don't let friends use alkaline batteries.
    Quote Originally Posted by Justin Case View Post
    Nice work.
    Yeah, I kind of thought about the x-axis after I finished posting them up. I can redo them in the next day of so to make for easier comparisons. I was also thinking of a single discharge test for all like size cells, but like you mentioned, what current. I was thinking maybe picking the lowest common denominator (lowest max discharge) for each cell size and using that current, seeing as each cell would only perform better from that point down.
    Quote Originally Posted by Battery Guy View Post
    DFiorentino
    Thanks. It's curiosity about my own mods and powering them that got me to finally do this; the 26500's in particular. I have a couple lights, LED and hotwire, using these 26500's and when you strike the match they are great, but sag quickly as voltage drops. I thought it may have been a heat issue, but alas, it's just the cells themselves. I've got 5 of them and the two tested here are the best (most consistent) of the batch. The others performed even worse, like 1600mAh @2.3A worse. It's like for a given length, going up in diameter doesn't increase power handling/capacity proportionally. Taking brand/manufacturer out of the equation the 18500's I tested performed better than the 26500's and the 18650's performed better than the 26650s. When you look at the C rating performance that is. I'd be really curious to test out an IMR 32650 to see how bad in does in retrospect. My connection for these tests was via your typical clamp:
    Stranded 12awg wire soldered (more like welded) to heavy brass contacts.
    -DF
    Apr 2010
    Portland, Oregon
    Quote Originally Posted by DFiorentino View Post
    Do you have a source for IMR 32650 cells? If so, please share! I would love to buy some.
    I wish I did...or at least I used to wish. Seeing these results makes me feel more comfortable going with a 2P 18650 setup. Though it does require a modded host more times then not. Even a 3P 17650 setup should be able to handle ~30A.
    -DF
    Aug 2011
    MD
    incredibly, y plotted as a linear function of x.
    aw imr 26500
    2300 2300 mAh
    2.3A 1950
    10A 1650
    19.1A 1380
    X Y
    I % of rated capacity
    2.3 0.847826087
    10 0.717391304
    19.1 0.6
    -0.014695968 slope, a
    0.875556926 intercept, b
    Y = aX + b
    Here's some predicted values.
    X ......Y
    2.3 0.8417562
    10 0.728597249
    19.1 0.594863942
    6 0.78738112
    15 0.65511741
    Quote Originally Posted by xul View Post
    19.1A 1380
    None of my 26500's were able to hold 19.1A without tripping the 3.00V cutoff first.
    -DF
    Apr 2007
    USA
    DFiorentino, can you come up with any reason why the AW IMR14500 performed so much better at higher discharge rates than AW's IMR16340's and IMR18350's? This doesn't make any sense to me.
    In theory the IMR16340's should have about the same capacity and the IMR18350's roughly the same or more by volume, don't they?
    Perhaps the IMR14500's are a whole different cell made by someone else. Or newer.. or different chemistry/mix?
    ampdude
    No scientific reason. I've known for a while from a practical standpoint that this would be the case, however. When you look at a lot of the reviews on here, similar lights always seem to fare better from a performance and/or runtime standpoint with 14500s as opposed to 16340s. The 18350s did shock me a bit; AWs especially. They underperformed at all discharge levels. Like i hinted to previously, it seems the "fatter" cells perform adequately when discharged near 1C. Crank up the juice and the story is different. It may just boil down to a manufacturing standpoint in that maybe the quality or quality control is better on say 18650s as they likely sell more than say 26500s. Or, I just don't know...
    -DF
    Apr 2007
    USA
    That's wild. Doesn't make any sense to me. Well I'm glad you tested them, very good information here, thanks.
    ampdude
    Aug 2011
    MD
    -DF
    BTW, the percentages should be multiplied by 100.
    I thought the graph showed this battery crossing the X axis at 1380 and 1650. It must have been the 10A line. Here's revision A.
    aw imr 26500
    2300 mAh
    2.3A 1950
    10A 1515
    X Y
    2.3 85
    10 66
    -2.456239413 slope, a
    90.43195935 intercept, b
    Y = aX + b
    X Y
    2.3 85
    10 66
    6 76 predicted, so you should get 1750 mAh at 6A. This third value will tell if the relationship is linear.
    Flashaholic* jasonck08's Avatar
    Sep 2007
    Redding, CA
    Can you not discharge the cells down to 2.5v? There is a large capacity loss at higher currents by discharging only to 3v vs 2.5v. Not to mention the added resistance in the wires means that you may only be discharging the cell to 3.1 or 3.2v.
    Also, can you measure the voltage drop of your clamp setup? For example take a DMM connected directly to the cell and compare it with what the logging software is reported at the given time. Even with my CBA, I get at least .1v drop on most currents over 5A.
    Default
    This is great -- thank you!
    Your measurements confirm something I've noticed but never verified: hard-driven single-cell lights don't last anywhere near as long as the stated battery capacity suggests. Bummer, because I love the pocket rocket form factor.
    One thing I'd love to see, if you have the data: how do these cells perform at intermediate currents, especially the common drive currents of 1.4A and 2.8A?
    Quote Originally Posted by jasonck08 View Post
    I can discharge down to 2.50V, but I don't see the point. The usable capacity below 3.00V is negligible or less. Look at the plots, they're going almost vertical by the time they hit 3.20V-3.10V. And yes, while discharging at 18A+ will technically net a higher numerical capacity number, it again is negligible. I was literally watching every discharge (about 4 times as many as I posted here) and as soon as the cells started hitting 3.30V I could watch them "fall off the mountain" if you catch my analogy. As for my rig, I just checked everything. The resistance was not measurable. Meaning I connected my test leads and measured 0.1Ω-0.2Ω; connecting across my entire setup (clamp contact to wire connection at charger) measured the same 0.1Ω-0.2Ω. And here's a quick standing voltage check (I'll check at a 10A draw in a bit):
    (FYI, if I sound defensive, I actually am not. I'm just trying to answer analytically.)
    Quote Originally Posted by flashflood View Post
    Thanks. If we can agree on some common test currents for certain size cells, I'll gladly do additional tests. I just don't want to do a bazillion more tests as this little endeavor took the better part of a week+. It's the recharging of the cells that I hate...
    -DF
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    0.1 to 0.2 ohm is way to high. But with the heavy cable you are using I doubt that you have that much.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Yeah, that is just with my spare test leads that weren't currently being used. All of the cabling in my test rig is 12awg for current carrying and for voltage monitoring; all soldered connections, no clamping.
    -DF
    I just did two quick tests at 5A and at 10A. It looks like I have ≤0.05V drop across the clamp to charger connection per 5A load. It actually was 0.04V @5A and 0.10V @10A. I can adjust my future tests to compensate, however I still feel the data gathered still paints an accurate picture of cell behavior. My main goal was to determine a cells ability to hold its rated capacity and at what voltage at 1C and at maxC to see if what I was seeing in the real world was my imagination or proof. Still I'll redo the high current tests.
    (The Fluke is connected at the cell to clamp connection; the Ideal (meter to the right) is connected at the wire to charger connection.)
    -DF
    EDIT: One thing I thought I'd mention is the iCharger's cut off works based on exceeding the voltage limit. Additionally, the time interval is 2 seconds. So, the charger ceases its discharge once voltage is <3.00V for 2 seconds. The capacities I recorded in the summary chart are taken directly off of the charger display and may not directly match the cut off on some of the charts. (Which can be visibly seen in a few as voltage was plummeting faster than the software was recording.)
    And this was the data that led me down this curious road:
    FM5x26500 host, Kiu socket, 64458 bulb, DD, AW 26500 cells... That's 1500 lumen lost in 44 seconds.
    -DF
    Ok, I redid the graphs to take into account the increased voltage drop as the current increases. It's just a quick fix until I redo all the 2A+ discharges this weekend. I'll double check my voltage drop at 20A to see if the drop is stable, linear or exponential. The graphs shouldn't end up looking any different, only the plots will be complete all the way down to 3.00V now. I also tried to make a common x-axis amongst certain size cells to help with the overall comparison.
    -DF
    -DF
    For the smaller cells (18650 and below) I would suggest 1.4A and 2.8A because they are such common drive currents. Moreover, adding those two curves should be sufficient to allow interpolation. For the larger cells, I'd suggest two currents between the min and max -- ideally logarithmically spaced, i.e. the ratio between currents should be the cube root of max/min. That will give you four nicely spread curves, two of which you have already generated.
    Flashaholic* csshih's Avatar
    Sep 2008
    San Jose, CA
    Quote Originally Posted by ampdude View Post
    14500s were developed by battery manufacturers much more than 16340s and 18350s (which are arguably niche hobbyist cells) - I know the 16340s are completely niche cells not used anywhere else.
    14500s are used in camera battery packs and the related.
    Craig
    Aug 2010
    ROLL TIDE!
    Very interesting thread!
    Does anyone know how well the IMR26650s perform around 7-8a?
    Aug 2011
    MD
    One thing I noticed with battery testing is that some people try to space the currents equally on a log scale, i.e., 1, 2, 5, 10 or 1, 3, 10, but I think it's more informative to closely space the currents when the curve is rapidly changing.
    This would require two tests; one to see where capacity vs. current is rapidly changing and the next to pick suitable currents.
    The short gaps can be filled by graphing capacity vs. current and eyeballing the intermediate zones or fitting a curve. One time, with curve fitting, I got a correlation coefficient, r, of ~0.9 doing this.
    Update: I'm redoing everything using the DCHG+ expanding discharge function of the charger. It uses the balance port to monitor the cell voltage separately from the current carrying wires. I made a balance connector that has its wire soldered directly to the brass contacts along with the load wires. I just did a 23A discharge and the voltage difference was within 0.1%. So another few days of discharging and recharging and I'll be right back where I was. After I redo the original work then I'll take on additional discharge requests.
    -DF
    Flashaholic* Black Rose's Avatar
    Mar 2008
    Ottawa, ON, Canada
    Nice work DF
    Sep 2007
    Redding, CA
    -DF
    Cool, and you should also discharge to 2.5v. Trust me, there is a lot of mAh left between 3 and 2.5v at higher currents (due to voltage sag). Sure not all the voltage will be usable in all applications from 3v down to 2.5v, but the cells capacity is rated to be discharged to 2.5v.
    You should also test the current accuracy of your hobby charger (verify it with a DMM at lower currents). I know the iChargers are usually pretty good within 1-2%, but sometimes other hobby chargers the current reading is literally 10% off.
    Things are looking better as far as repeatability and accuracy. I'm confident in the voltage signal now and I just did a current check; it's within 0.000A-0.005A @0.05A discharge, but also 0.000A-0.005A @0.50A discharge. It looks like its resolution is limiting its accuracy (by percentage) at very low currents, but for my purposes of 0.50A and up, any variation is probably not practically appreciable. As far as cutoff is concerned, apparently I'm locked into the 3.0V cutoff. Using the LiPo selection (3.7V/1S) the lowest discharge is 3.0V. If I could select LiIo (3.6V/1S), I can go down to 2.5V, but it won't let me select that option as the battery peak voltage detection expects 4.1V and I get an "over" warning. Oh well. One change I am making is I WILL NOT be using my Ultrafire chargers for this testing anymore. While my completed charge voltages were varying by only small amounts, I found the available capacity varying significantly from charge to charge. I plan on using the iCharger or my Triton (@1C) or the 4Sevens charger as they have proven to be fairly consistent.
    -DF
    Sep 2007
    Redding, CA
    -DF
    You should be able to use the Ni-mh discharge setting and program in 2.5v cutoff. It's usually not as picky. At least thats the way it works with the cheap Turnigy style chargers.
    Apr 2010
    Portland, Oregon
    -DF
    DF
    How did you make these lumen measurements?
    Cheers,
    BG
