Foxfury Scout
Results 1 to 15 of 15
Thread: The Versuvius, my favorite AAA sized light. Beamshot comparison...
    Default The Versuvius, my favorite AAA sized light. Beamshot comparison...
    With a momentary switch, and a modified Moddoo clip, I will be carrying this light quite often. And I've gotta say, the ramping of this light is the smoothest I've used on any Peak light to date.
    Here is a few beamshots of the Versuvius to show it compares to a few other lights that I had on line.
    Peak Eiger Narrow Beam rated at 225 lumens according to Bob at em-mgt.com.
    Peak Logan rated at 300 lumens according to Oveready.
    Mac's Customs XM-L EDC that's rated at 575 lumens as tested by Mac.
    And here's the Versuvius that's supposed to have a bare bulb output of 650 lumens. Probably has a OTF output of around 500 lumens.
    As you can see, the beam is very floody. The beam actually resembles the Mac's Custom Tri-EDC. And here's a pic of the LED in moonlight mood. I could actually get the bulb even lower, but it was almost too dark to photograph.
    Just one awesome light.
    Ask me about custom kydex.
    Sep 2005
    Glendale, Arizona
    Default Re: The Versuvius, my favorite AAA sized light. Beamshot comparison...
    Very nice pictures and beamshots. Thank you.
    Peakaholic!
    Jan 2006
    Arnieland
    Thanks for the beamshot comparisons Death's Head, it will help me in deciding my next purchase. I was thinking about picking up another Vesuvius or Logan, but now I'm torn between the Rainier, Everest, Logan, Vesuvius or Eiger (in that order).
    Peaks are addictive!!!
    Funniest CPF thread ever. I promise it'll make your day.
    Flashaholic* Derek Dean's Avatar
    Nov 2006
    Monterey, CA
    Very nicely done..... both the beamshots, which do an excellent job of showing the relative beams, and the way you've finished out the Vesuvius with a nice clip and momentary switch. You've done Curt proud!
    I'm curious, which momentary switch are you using with that clip? From what I can tell there seem to be 3 different switches to choose from with varying lengths of contact point.
    Jul 2006
    N 03°13.884° / E 101°29.329°
    a really nice radiation pattern for an AAA light
    That light looks awesome, and seems like a perfect EDC light! I've recently jumped into buying AAA lights and absolutely love the form factor, and one with peak build quality, the huge lumens, clip and momentary would be hard to pass up. Can you elaborate a bit more on the clip and momentary switch? I thought the momentary switch was a no-go on this light, and I haven't seen a clip on an eiger-sized light before.
    As an aside, it hardly seems worth it carrying a huge light around anymore when there is a generation of tiny, AAA-based lights that can run on rechargeables and make much more power.
    You have a great light there, may it serve you well!
    Quote Originally Posted by jonesy View Post
    Thanks man.
    Here's a video that shows a modified clip on an Eiger, which has about the same body as the Versuvius.
    http://www.youtube.com/watch?v=XKY5A...&feature=feedu
    The clip was purchased from Oveready.com. It is designed for Peaks with a wider diameter body such as the Logan and El Capitan. The portion of the clip that keychain attachment or momentary switch is threaded through has been grounded down so that it is flush with the narrower body of the Versuvius. You can see that the clip sits up higher on the body of the Versivius (and Eiger in the video). Doesn't look at of place to me though. And the clip functions perfectly. This is my second modified clip, and so problems to report. I think Oveready plans to make Eiger sized clips, but not sure when it's going to be, but in the meantime, I'm perfectly satisfied with these modified ones.
    And to answer you question with the momentary switch. The momentary switch does work. There are two QTC compatible momentary switches. One is longer while the other is shorter. You will have to purchase the longer QTC version. I believe Bob only has the new, shorter ones, and these do not work properly with the Versuvius. The previous longer QTC momentary switches are still available at Oveready though, but I'm sure Bob can acquire some as well.
    Also, I'm with you with the AAA sized lights. I'm a huge fan, regardless of the disadvantages of having a smaller battery, and not to mention the heat generated from this light when having it on full power for more than a few minutes. But for my needs, this light will serve me well.
    Where can i buy this light?
    Nov 2006
    Monterey, CA
    http://www.em-mgt.com/LED/Vesuvius.html
    Please, do read the warnings before purchasing this light. It requires the use of specialized batteries, charger, and the knowledge to use it all safely and responsibly.
    Oct 2006
    Connecticut
    Thanks for the great pics, really gives a great idea of the beam. I'm curious on the operation of the peak momentary with QTC. Do you push a little for a little light, more for, well, more? Twist the head for constant as with a non-momentary switch? Or does the switch just turn on the light (momentarily) to wherever the head is currently tightened? WOuld this make it two hands necessary to adjust while the light is on? I'm curious about this, but if it is the first option I mention, I might be buying this set up very shortly!
    Thanks!
    Jan 2006
    Arnieland
    It is as you described in your first option. You have to push pretty hard to get to full output though, and if you have big hands like me it's not easy to hold onto. The Logan is a bit better in this regard due to its larger size.
    Flashaholic Draven451's Avatar
    Jan 2006
    USA
    The Vesuvius looks like one Awesome light!
    "Light up the Darkness"
    Flashaholic* moeman's Avatar
    Jan 2003
    St. Louis, Missouri
    I wish Peak would make some more! I would like to try one.
    "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin
    Dec 2005
    I am Kenny Powers
    how does this compare to the Eiger X?
    all lights: view here (4Sevens, Surefire, Malkoff, Ra Lights, etc.)
    Flashaholic* archimedes's Avatar
    Mar 2011
    CONUS, arteriosus
    Vesuvius was rated at approximately 650 bulb lumen (XM-L emitter), versus the Eiger-X rated at approximately 425 bulb lumen (XP-G emitter).
    The Vesuvius has a relatively floody beam, as does the Eiger-X. The Eiger-Ultra-X is similar to the Eiger-X (both 425 lumen XP-G LED), except the larger Logan-sized bezel and narrow optic provides more throw (a "turbo-head", if you like).
    I do not think the Vesuvius is currently in production, however.
    IF 2 = 1 THEN 1 = 0
