BrianMc
- Joined
- Nov 4, 2009
- Messages
- 940
A new Cygolite Hotshot showed up today (it was $20 cheaper than the $42 they want today, so I must have caught a window of a misprinted webpage opportunity or maybe it was a loss leader?), best currently elsewhere, is about $31. At $22 it was irresistible.
Beam: Hot spot: 10 degrees, circular.
Output: Over 61 lumens* (I suspect about 100) on max & steady, completely adjustable
Runtime on max & steady: 4.5 hours claimed (unverified)
* Confirmed the output to be circa 60 lumens with Dnager Zones at 22-25, Radbot 1000 in the 30-32 range, the Turbp about 35 lumens and the DIY at 105 as before. The absolute values may be sightly off bu the relationship will be valid.
I will add pictures to this thread later. So how does it compare?
To what? Well it is a USB li-ion self contained light with a narrow spot optic, and a powerful LED. The Knog Boomer is much weaker (15 lumens = original PBSF + 20%, the Blackburn Flea 2.0 with four 1/4 watt LED's and no lens isn't a peer either. At less than $35 it is competitive with the Planet Bike Turbo in cost, intent, beam type and use and is king of the AAA tail lights in brightness. Too bad they don't make a AA version. It is nice to carry more runtime in your pocket.
The Planet Bike Turbo is supposedly about half as bright as the HotShot, by my first measurement. By the beam on the wall? No way it is that close. True the Turbo's hot spot is 50% bigger in height (same width) and that dilutes the power. The HotShot has a brighter spill, plus some fingernail clipping red spots from the reflector at about 120 degrees. Side output is superior to the Turbo as well, a strong red versus a reddish glow, again about 4 X by eyeballing it
The Narrow 10 degree primary beam means aiming it is critical. It should prove to be a great thrower at full power in daylight. This IS a light to back off at night especially if you are taking the lane and drivers will be directly behind you at times. Maybe highest power for low sun angles only. Many times brighter than a car's brake light. How much, I will measure or video. You can back it down to get 100's of hours of runtime, so it can be a meek little light, if you want. It cycles through levels holding the intensity button down. Dial an intensity. So you can back it off until your riding buddies are happy. Or on a longer ride as the sun lowers, it is a shot stop and button press to up the output, and as the sun goes down another easy press to back it down. This adjustment is available in all modes and those includes a 'zoom' or fade/brighten mode as well as several flash variants.
It weather permits, I will try for a test including riding into and away from a lowering sun. Worst case situation where the power and spot beam may be the ticket to help drivers see a cyclist. I purchased it to complement the 270 degree coverage that two Red Zone 4s provide. So far, it looks like a perfect pairing. Spread plus tunable throw. Like normal headlights and a NiteFLUX WZ 5 up front. I'll keep you informed.
BrianMc
BrianMc
