Malkoff
View Poll Results: Haiku. Which Battery Do You Use?
Voters
95. You may not vote on this poll
  • Unprotected R123
    1 1.05%
  • Protected R123
    48 50.53%
  • Rechargable IMR
    14 14.74%
  • Primary - SureFire
    19 20.00%
  • Primary - Other
    13 13.68%
Page 4 of 5 FirstFirst 12345 LastLast
Results 91 to 120 of 132
Thread: Haiku Batteries. Which Do You Use? Primaries or Rechargables?
  1. #91
    Oct 2009
    Vancouver, BC
    Default Re: Haiku Batteries. Which Do You Use? Primaries or Rechargables?
    Yes, they are good for just about all Li ion rechargeables. They have multiple settings from low ( small batteries), to high ( large capacity).
  2. #92
    RedLED's Avatar
    Oct 2006
    Palm Springs, CA, Beverly Hills, CA, Washington, DC, New York City Manhattan
    Thanks for the advice, launch Mini!
    Check my Web Site: www.Redwayphoto.com
  3. #93
    RedLED's Avatar
    Oct 2006
    Need some battery help...from the knowledgeable!
    I have an AW 16340 RCR 123 protected in my Haiku and went on a 4 day trip to Philadelphia. I charged the battery 4 days before, as it usually lasts a very long time, and I did not use the light on the trip much.
    Aboard the aircraft on the way home I needed to check the floor, and it just went off - dead off. Is there a problem with this battery? Normally, I get up to three weeks at most with normal use of on a charge of it sometimes.
    In the end it was not a problem as I pulled out one of the four other lights I had on me, including my XML Haiku. I just did not want to haul another charger on the trip as is was so short.
    Any thoughts to limited use with recent charge? And why it just snapped itself off or is this normal?
    What I was doing was checking on our Philadelphia cat under the seat, we moved the feline to our desert home with the rest of our cat family.
    Thanks for any info.,
    Best,
    NR
  4. #94
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Did the protection circuit trip ?
    ... is the archimedes peak
  5. #95
    RedLED's Avatar
    Oct 2006
    How does that happen?
  6. #96
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Various possibilities ... overcurrent, overdischarge, short circuit, etc, etc ....
  7. #97
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    What is the voltage ?
    How old is the cell ?
  8. #98
    RedLED's Avatar
    Oct 2006
    Bought in July of 2016. 3.7 V
  9. #99
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    So it provides absolutely zero output, sitting now at 3.7V ?
    Does that Haiku work properly with a different (fresh) battery ?
  10. #100
    RedLED's Avatar
    Oct 2006
    The rechargeable went off, and I put a primary CR 123 and it came back to life.
  11. #101
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    So the rechargeable in question is still at 3.7V, has not been further recharged or discharged, but will not power your Haiku ?
  12. #102
    RedLED's Avatar
    Oct 2006
    Well, I charged full after about two weeks, and into one week with little use it just came on for a second then was dead after that. Just went off. It seemed to charge normal today, just like normal.
    It's that it has never caused the light to fail like that before. Up to now it has worked just fine.
    when I put it on the charger, it was dead, however it has never just stopped working like that before, normally you notice switching issues of the 3s modes and it is time to recharge, not a complete blackout of the Haiku.
  13. #103
    RedLED's Avatar
    Oct 2006
    After charging the battery it powers the haiku as normal.
  14. #104
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    It sounds likely that the protection circuit tripped, possibly inappropriately.
    I would suggest, at the least, clearly marking that specific battery as questionable (perhaps defective or damaged)
    And, if you would rather not have to worry about it, simply replace it.
  15. #105
    RedLED's Avatar
    Oct 2006
    I think you are correct, I will replace it.
    Thanks so much for taking the time to help me with this battery problem.
    Much appreciated.
    Best,
    NR
  16. #106
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    You're welcome, cheers !
  17. #107
    RedLED's Avatar
    Oct 2006
    One more question on these protected batteries, should you wait until they go dead or so low it is hard to shift modes, or charge them once a week or something of that nature?
    This battery caused the most reliable light made in the world to unusable.
    Again thanks,
    NR
  18. #108
    Flashaholic* Slumber Pass's Avatar
    Sep 2011
    The Alamo City
    Default Haiku Batteries. Which Do You Use? Primaries or Rechargables?
    What was the voltage on the cell before you charged it again (after the incident)? Any possibility the switch on the light may have been activated and drained the cell?
  19. #109
    RedLED's Avatar
    Oct 2006
    When I went to charge it was dead, I don't think it came on in my pocket, I would have felt that. I was flying do the X-rays hurt them?
    I look at it and no longer trust it.
    Thanks so much,
    NR
  20. #110
    Flashaholic* jumpstat's Avatar
    Dec 2006
    Ampang, Malaysia
    RedLED,
    Similar issue happened to me in the past on 2 occasion. Both when I went on away trips and both having different 16340 AW Protected black cells. The cells I bought was in 2008 and this occurance happened sometime late last year. Thinking that the cells are ageing, I bought another batch to power up my lights as I too bought in a batch the same time in 2008. So having 2 issues would also mean that the rest of the batch would eventually fail. Anyway new fresh cells came in and when I tried to charge it, I noticed that I was having contact issues with the charging post of the charger. I was using the WF-138 charger. And only then did I realised that, the issue was with the charger and not the cells. Bought another charger the Xstar VC4 which displays charge current and mah, and all my old cells are working to this date albeit reduced capacities. For me I charge these batteries as and when they trip the protection.
    SF E1L McGizmo HA PD-S Ti Mule-PD BB Haiku-XP-G Inova X1
    CRK 21L Umnumzaan Strider SmF ZT0560BK SPY PM2 BM 556 551-1302 ​LSTEEL HEAT HEFT4
  21. #111
    RedLED's Avatar
    Oct 2006
    My battery was from July 2016, and I would say it is still kind of new. My charger is an xtar VC2.
    Is this battery any good to use, should I give it a second chance or toss it and replace it? Any advice is welcome. I have switched back to a primary for now.
    I have many Mc Giz lights, however, my EDC Haiku XPG R5 is the one I was using the protected rechargeable in.
    Thanks,
    RL
  22. #112
    Dec 2011
    NJ
    In all honesty, the light was either accidentally activated or never fully charged to begin with. It isn't really likely the protection circuit broke unless you use it in a recoil environment.
    Try the cell for a while where you aren't worried about being left in the dark and if it works its fine. If the protection circuit fails prematurely then either take the circuit off and use the bare cell in a light with a built in protection circuit or toss it.
    I would also suggest getting a multimeter and measuring the voltage of the cell at points in time. When the protection circuit trips and you bring it back to life but before charging it reads 3ish volts you know it's working fine. But if it trips and then you read 4 volts still then you know the circuit is defective. 3.7v is the nominal voltage of the cell and doesn't really say much as all li-ion are that for al intents and purposes.
    Theres no real danger past it shutting off prematurely worst comes to worst.
  23. #113
    RedLED's Avatar
    Oct 2006
    Thanks, I do have a DMM and will check it. I gave it a charge after it tripped and it has Been just sitting here unused except to put it back in the light to see if it worked, and then removed it.
    I will give it another try. Should I measure it and use it or top it off on the charger first? Also, my DMM can put a load on it for testing should I use that setting or just measure the straight voltage?
    Thanks so much for the advice.
    Best,
    RL
  24. #114
    Dec 2011
    NJ
    I would top it off in the charger, let it rest at least 10 minutes and check the voltage with no load. Then measure it the next day. The voltage should not drop by more than one or two .1 volts. If you see it measured at 4.15V off then the next day drops to 3.9V either repeat the test wondering if there was an error in the measurements perhaps the contacts on the DMM weren't seated correct or you can assume the cell is defective and recycle it.
    This is a quick way to measure the self discharge of a cell, which is a good first step to determining the health.
  25. #115
    RedLED's Avatar
    Oct 2006
    Thanks, I will do that and see what happens.
    Once again, thanks for the help.
    RL
  26. #116
    Does anybody know if KeepPower batteries will fit?
  27. #117
    Quote Originally Posted by ca2fl View Post
    BTT
    The Keeppower batteries are to long, its a difficult to screw the head without crushing the battery.
    The AW ICR RCR 123 Protected 750mAh Black/Silver label on the way.
    I'll let you know how they fit.
  28. #118
    The KeepPower batteries are to long for McGizmo Haiku lights and are difficult to screw the head right on.
    I shortened the spring to half on McClicky switch and now , the AW ICR RCR 123 Protected 750mAh Black/Silver label battery fit absolutely great,
    and KeepPower also fit good.
  29. #119
    Not to tell people what to do with their batteries, but the low voltage cutoff on a protection circuit is there as a last ditch effort to avoid the cells being discharged so low that it may damage the cell. I would not recommend intentionally discharging the cells until you hit the cutoff because it will shorten the number of cycles the cell can deliver. The cutoff usually is set at 2.5 volts, however I would recommend charging lithium batteries by the time they get down to say 3.5 volts. This will pay off in the form of improved long term cell health.
    PS To answer the question I've been using rechargeable batteries exclusively in all of my lights and I've been using variations of rechargeable lithium batteries since the hobby level radio control industry started using them around 2004 or 2005.
  30. #120
    RedLED's Avatar
    Oct 2006
    Quote Originally Posted by Beard Man View Post
    I have the exact same battery, and it fits perfectly, just Like a primary cell. Could AW's QC be off?
    ADD: just measured my AW, and a Surefire CR123, and the AW is one millimeter taller, that is going to be taken care of by the spring. Beard Man, can you measure yours and let us know if it is longer compared to a primary? The primaries should all be pretty consistent in legenth. It would be nice to know if they are off somehow.
