ArmyTek
Page 10 of 28 FirstFirst ... 3456789101112131415161720 ... LastLast
Results 271 to 300 of 834
Thread: Nitecore "Tiny Monster" TM11 (4x18650, 3xXM-L) Review: RUNTIMES, BEAMSHOTS, VIDEO +
  1. #271
    Default Re: Nitecore "Tiny Monster" TM11 (4x18650, 3xXM-L) Review: RUNTIMES, BEAMSHOTS, VIDEO
    I also use the 3100 Redilast and the cells have been great so far in my TM11. One thing to note is that they aren't really a button top or a flat top. They are almost like a slightly raised flat top. This did cause me to have a bit of an issue in my charging cradle since the battery could not reach the charging terminal due to it not being a "true" button top.
    JD
  2. #272
    Btw, my Redilast 3100 mAH Button Tops, and my AW 2900 mAH Flat Tops, both fit my Pila, DSD and Ultrafire WF-139 Chargers superbly too...
  3. #273
    Oct 2007
    Toronto, Canada
    Has anyone noticed that the manual lockout feature of unscrewing the body slightly has changed since new? When I first got this light I remember being impressed that it only took a 1/4 turn to disconnect the batteries, but now I find I have to do a 1/2 turn and sometimes closer to 3/4 of a turn. When I examine the anodization of the threads very closely I see a couple of areas on both the head and the body that appear to have worn through and in fact they actually conduct (tested with a multimeter). I believe these worn areas, if they line up with each other, could be allowing an alternate ground path even once the primary path through the bare end of the body to the gold ground ring on the head has been broken.
    Reading over the manual Nitecore doesn't mention the quarter turn method to completely lockout the light, only the switch activated method, so I'm going to assume they will not consider this a problem.
    Last edited by kwarwick; 02-21-2012 at 06:26 PM. Reason: clarify offical lockout mode vs. 1/4 turn method
  4. #274
    Quote Originally Posted by kwarwick View Post
    I have noticed this as well. You pretty much summed it up nicely.
    JD
  5. #275
    Thank you all for really quick and kind replies. I am going to check all the recommendations right now. I have already found a reputable and cheap eBay seller to buy a TM11 from. Therefore, few batteries and a charger is all I need to fulfill my obsessive needs. :)
    HKJ, your deep battery test is really impressive. Looks like I will pick up RediLast 3100 mAh.
    Quote Originally Posted by peterharvey73 View Post
    I use Redilast 3100 mAH Button Tops, because they were the highest capacity battery available with protection circuits, and a button top; the Redilasts work superbly, no problems.
    What I really like on your reply is the fact that you named a particular brand and model. I do not want to make a mistake buying a slightly different model rendering the combo completely unusable. So this is exactly what a newbie needs. :)
    You also addressed existence of cells with a built-in protection circuits. This would be my point 4! Really, I forgot to mention it. I am partly a pyromaniac but I prefer not to combine my hobbies this way. :)
    As of the Pila charger, I have found only one seller on eBay and he does not ship internationally. Do you know of a reliable source for these? PM me please, if naming one would break the forum rules.
    Do you think the Ultrafire WF-139 performs equally well?
    This one can be ebayed easily what is a real time-saving feature. :)
  6. #276
    Retired Administrator Norm's Avatar
    Jun 2006
    Australia
    Quote Originally Posted by nico View Post
    Naming the seller won't break the rules, linking to the seller will.
    Norm
  7. #277
    Yes, HKJ's battery tests are an incredible resource.
    But as for the Redilast 3100mAh, be advise that at least one member in this thread has reported problems. I know from my testing that any cell over 69.0mm may have an issue in a particular sample (e.g. I had one TM11 that wouldn't take 69.0mm and taller, and another that has taken everything up to 69.2mm). See the comments in my review, and in posts #160 and #169 here.
    At the end of the day, you will be probably be fine with the Redilast 3100mAh, based on most experiences here. But there is still a small risk of a compatibility issue very long cells.
    Full list of all my reviews: flashlightreviews.ca. Latest hobby: whiskyanalysis.com. New: Selfbuilt's Spring 2018 Sale!
  8. #278
    You can buy from Redilast themselves:
    http://www.cpfmarketplace.com/mp/sho...n-Japan-Korea!
    [Can use existing username, but must register with new separate password for cpfmarketplace.com].
    It should be 68.5mm long by specs.
    Just email them directly, and ask them to verify the overall length with a pair of electronic calipers before they freight.
    As for the WF-139, please read Eric's thread here:
    http://www.candlepowerforums.com/vb/showthread.php?229923-Consumer-Li-Ion-quot-cradle-quot-charger-roundup... .
    Without reading Eric's article, I can't tell the difference between the WF and the Pila; I have no multi-meter.
    However, the 250-350 mA charge rate of the WF will be very slow compared to the 600 mA charge rate of the Pila charger.
    You'd want a fast charger to recharge 3100 mAH of capacity.
    Eric does not recommend the WF-139 for various other reasons like the charging method, and the overcharging etc.
    The Pila charger is best; you can buy it from many retail outlets like bugoutgearusa.com etc...
  9. #279
    Oct 2006
    Maui, Hawaii
    Default
    Bought my Pila IBC charger and Redilast 3100 cells from Lighthound website.
    Sent from my ADR6300 using Tapatalk
  10. #280
    I just want to add that I have received a third (so far perfectly working) TM11. It came with version 3XML-V1.12-1111. I can only recommend you try to get one of those if you also want one. You will be surprised by the amount of light it makes.
    It is on my desk running for 1:30 without problems.
  11. #281
    Hi!
    Just a check. Anybody here has the TM11 tested with Panasonic 3.7V 18650 rechargeable batteries? I may have a problem buying the Redilast batteries from the net and ship into my country directly (without questions from customs) but I believe I've a good chance of getting the Panasonic batteries from ebay Singapore instead without issue since it's already on my country's ebay (Singapore) website. Too bad I can't find Redilast batteries on ebay Singapore.
    http://www.ebay.com.sg/sch/i.html?_p...50&_kw=battery
    As charging the batteries would take some time I intend to buy 12 pcs - 4 pcs for use in the TM11, 4 pcs on ready-charged standby and 4 pcs just in case any battery konk out as well as for standby. A
    Are the Panasonic batteries dimensionally same and perform equally as the Redilast batteries? May be someone can point me to a link where other brands of batteries (besides Redilast) can be used in the TM11 without problem.
    Getting the 2x Pila IBC chargers and the TM11 in should not be a problem
    Thanks
  12. #282
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    Quote Originally Posted by Sigmasailor View Post
    Where is the version labeled or displayed?
    Thank you in advance.
  13. #283
    Quote Originally Posted by Patriot View Post
    On the inside of the head...
  14. #284
    Quote Originally Posted by Travelmate View Post
    Pretty much all 3100mAh batteries use the Panasonic NCR18650A core. The different brands differ in the positive contact point (small button, large button, or flat-top) and the protection circuit design and features. This affects their overall length and protection shut-off points, but they should perform roughly similarly at different current drains.
    HKJ has an excellent 18650 battery comparison thread here: http://www.candlepowerforums.com/vb/...review-summary
    If you scroll down, you will see graphs for voltage/current patterns and height differences between the various brands of cells. The cells you link to on eBay seem to be some generic brand claiming to use the Panasonic NCR18650A core. If that is true, performance should be similar to other 3100mAh cells. But overall dimensions are hard to know on these generic brand batteries.
    May general recommendation is to make sure your brand of cells is under 69.0mm total length, to ensure reliable operation in the TM11.
  15. #285
    Eric does not recommend the WF-139 for various other reasons like the charging method, and the overcharging etc.The Pila charger is best; you can buy it from many retail outlets like bugoutgearusa.com etc...
    Thank you very much. I will buy the Pila charger from the seller you have recommended. They do ship internationally so everything is perfect.Last question ... and please consider it funny not stupid. :)I know there is a lot of battery setups TM11 can take. If I go with the RediLast cells, how many of them I need (one load)?
  16. #286
    Thank you very much. I will buy the Pila charger from the seller you have recommended. They do ship internationally so everything is perfect.Last question ... and please consider it funny not stupid. I know there is a lot of battery setups TM11 can take. If I go with the RediLast cells, how many of them I need (one load)?
    If you use less than 4x18650's, you may only have partial output?
    Less than 4x18650's is only for emergency use.
    You need a full set of 4x Redilast 18650 3100 mAH Button Tops.
    Four 18650's of the same batch must be used together simultaneously.
    We can't mix 2 old 18650's, with 2 new 18650's.
    We also cannot mix 2 half charged 18650's, with 2 fully charged 18650's.
    The four batteries must be the same: the same make, the same model, the same age, and the same level of charge too.
    If you are a heavy user, you may want another set of 4x Redilasts for use as backup...
  17. #287
    Flashaholic kwak's Avatar
    May 2011
    Athens, Greece
    Guys quick question please.
    I have a TM11 on it's way and plenty of 2200mAh AW cells, but as i'm about to order some Redilast cells for a mate i figure i may as well order 4 extra 3100mAh's.
    Can someone please confirm 100% that Redilast 3100mAh cells work in the TM11?
    Cheers
    Mark
  18. #288
    Quote Originally Posted by kwak View Post
    Cheers
    Mark
    I am using those cells in my TM11. many of the folks here are as well. So far only 1 user has stated that the cells did NOT work in their light. There is plenty of info about it in the thread.
    JD
  19. #289
    Jan 2002
    Kansas City, MO
    I'm planning on getting one of these in the near future. Would anyone not buy a TM11 again? How does the neutral tint look?
    edit:
    I ordered one in neutral tint (T5) on eBay for a substantial discount and should have it on Wednesday. Almost enough to buy a Pila IBC.
    SureFire A2 .:. SureFire G2Z .:. SureFire M6 .:. Power on Board 35W HID .:. LUMINTOP IYP365 219BT .:. 4Sevens Quark Tacticals: QTL, QT2L-X w/ Burst, QTA, QT2A-X
  20. #290
    Feb 2007
    Arizona
    Please pardon if this has been previously answered, but how much current does the TM11 draw at full output (turbo)?
    Thanks
  21. #291
    Oct 2006
    Maui, Hawaii
    Default
    [QUOTE=FNG;3890597]I'm planning on getting one of these in the near future. Would anyone not buy a TM11 again? <snip>
    I've had mine since January and I've been satisfied with the performance and operation. For the price, I'd say it's worth it.
  22. #292
    Quote Originally Posted by FNG View Post
    edit:
    I would for certain buy it again. Mine is cool white though. I would have purchased the neutral white version but it was no longer available from my vendor.
    JD
  23. #293
    Nov 2011
    where we can buy the version .3 of the nitecore tm11? waht shop are 100% best????
  24. #294
    Quote Originally Posted by ciccio90 View Post
    Just email them, and ask them do they sell the version V1.12-1111, because you only want this particular version...
  25. #295
    Anyone use this CEnergy Smart-4 battery charger for 4-bay x18650 (and others) charger? I saw it at a shop in my place but seems not to find it on the net? The item is made in China
    Thanks
  26. #296
    Or ask them to do a 'burn in test' before shipping. Number 1 and 2 failed within 30 minutes. I guess if they live after a first set of batteries on Turbo you will be OK. The V1.12-1111 did the trick in my case.
  27. #297
    Thanks
    My own feeling on something like that is that if you can't easily find product or review information on the internet about that charger, I wouldn't consider buying it.
    You might want to ask that same question in the Flashlight Electronics - Batteries Included section of the forum and see if you get any feedback (the question is probably more appropriately asked in that subforum anyway).
    I wonder if the "Blue Star 4-Bay Charger" is the same thing you've seen? (Google it.) Also, though -- I see no useful info posted about that charger either. That is, this company actually makes one....but is it any good? I'd be very hesitant to buy it or use it, personally.
  28. #298
    Quote Originally Posted by varuscelli View Post
    Thanks I'll head over there
    BTW, the 4-bay x 18650 battery charger I quoted is not the same as the Blue Star 4-Bay Charger you quoted. The one I quoted can charge 2 different sizes of batteries and each bay has individual battery status indicator.
  29. #299
    gotta get me one of those
  30. #300
    I have come to thank you all. Thank you for your help and friendly advice.I have received three separate packages in last few days. The very last one has just come. In other words, I am charging right now. :)
