Hi,
just some weeks after ordering, and less than 2 weeks after sending confirmation I received my H600 today.
Info: I am from Germany, the package came from China.
I promised to write a short review. (Same on a German Forum)
Here we go:
I will keep it short, since I am no litterateur.
Usage: Typical Zebralight UI. I really like it.
The low setting is really very low, just as I like it.
The High is really really high. Much more than my other lights. (e.g. Zebralight H31)
The light levels are evenly spread.
The mix of spot and spill is really perfect. Enough spill for universal usage, good spot for distance.
The color ist white-yellow in the spot and getting blue-white in the spill. During normal usage you won't even recognize this.
Scope of supply:
Typical Zebralight also in this area:
Headlamp, spare-o-rings, strap. Nothing else!
Quality is perfect, just as I am used to it when thinking of Zebralight lamps.
Battery:
Flat-Top Sanyos are working well, there is a spring inside.
Inner tube diameter is 18,65mm. (The red Sanyo's fit perfect)
Switch:
Is somewhat deeper in the body and needs quite a bit force. I think unwanted switching is hardly possible. Nevertheless the lockout by unscrewing the tailcap is still possible.
The headstrap is slightly changed compared to my older H31 for example. One side of the rubber strap is thicker than the other. I really don't know what might be the reason for this, maybe some improvement in stability on the head???
Time will show that.
Conclusion: I really like it. Have been searching for something like that quite a while!
Photos:
Unboxing:
Strap:
LED:
Tube:
Flattop is ok:
Beamshot H600 Turbo (750 lm):
Beamshot H600 420 lm:
Compare it: Zebralight H31 220 lm:
Compare it: Zebralight H31 120 lm:
Compare it: Eagletac D25LC2 Neutral White Turbo:
Cheers!
Psybadeck
Here we go:
Scope of supply:
Battery:
Switch:
Photos:
Unboxing:
Strap:
LED:
Tube:
Flattop is ok:
Cheers!
Psybadeck
