The Luminus SST-90 is a 3mm x 3mm square for a total of 9 mm square die size.
The Cree XM-L is 2mm x 2mm for a total of 4mm square die size.
The Cree is newer in design, so it is more efficient.
The Cree XM-L can be driven up to 3 amps within recommended specifications to produce 1000 emitter lumens.
However old, the SST-90 is still much larger in size, so it can withstand more heat build-up, thus it can be driven to 9 amps in recommended specifications to produce some 2200 emitter lumens.
Because the SST-90 is larger in size, and produces more lumen output, it will tend to have a larger hot spot, and have a brighter spill, and more overall flood.
I am not exactly sure of the surface brightness of the SST-90 versus the XM-L, however from my memory, the SST-90 is no slouch in surface brightness at all - in fact it's surface brightness is better than the old XPG-R5, and only slightly inferior to the very old XR-E R2.
Thus, throw will be mostly dictated by the diameter of the reflector, not the surface brightness of the emitter.
Btw, just because the surface area of an emitter is large, it doesn't necessarily mean that it's surface brightness will automatically be low.
Also, just because the emitter is larger, it doesn't mean that it must have a proportionately larger reflector to throw as well as the smaller emitter.
These are common mistakes I use to make myself in the understanding of throw etc.
Don't focus too much on paper specifications, and generalisations about emitters.
At the end of the day, the best way to compare the two flashlights is to switch them on, and test them side by side.
If not possible, look for youtube videos of their beam performance to help.
Or if worse gets to worse, start a new thread on cpf like this one, for help...
