Angryfox
Page 1 of 2 12 LastLast
Results 1 to 30 of 47
Thread: How about a nice 2 x D flashlight?
    Default How about a nice 2 x D flashlight?
    The time has come for a GOOD, inexpensive flashlight designed to run on 2 x D sized alkaline batteries. I would like 250+ lumens.
    I love my exotic beasts but the kitchen drawer needs a 2D, it just does.
    These batteries are so inexpensive on sale I don't want to bother with rechargeables. I'd like to push the envelope without rupturing them. Seems to me they should be able to power an r2 for throw or an xml or xpg for flood.
    Personally, I think flood is more practical indoors where it is most likely to be used so xml seems the best candidate but S2 could be nice too.
    I've looked at the various mods for maglites but they are expensive and a pita to install. I'm looking for easy here.
    I miss the 2 D cell size and simplicity. (I dont miss the crappy beam they put out with incandescent bulbs)
    New expensive flashlights in that format require nimh which I find a pita. Obviously, the flashlight should be priced under $50 because alkalines do frequently leak and ruin. Even with that weakness I prefer them because they are so cheap and easy to use. How about it?
    Please don't whine about leaking and lack of energy density. This thread is about solutions. We all know the problems.
    Flashaholic* Robin24k's Avatar
    Sep 2009
    Washington, USA
    Default Re: How abous a nice 2 x D flashlight?
    The new Maglite XP-E 2D should be a good choice, or if you're open to C-cells, the ML100 will be even better.
    Dec 2009
    USA
    Rayovac makes 2 models that fit the inexpensive light with flood They work great around the house.The yellow one has 3 led's that are slightly on the warm tint side. The other one is like neutral white.
    Default
    I'd really prefer an xp-g or xm-l. I was hoping 4sevens or another decent but not outrageously priced brand would produce one. Maybe an addition to jetbeam's new inexpensive line or something from shiningbeam?
    I'm not even blowing off Dx
    tk50,
    Default
    Really nice flashlight but too expensive and designed more for throw outside than for indoor use. Its really my only decent choice at the moment but I'd like something cheaper. I've had my eye open for a used ine cheap but no dice.
    Default Re: How about a nice 2 x D flashlight?
    i keep duracell daylight 2d in my car, (the one with aluminium body, not plastic, thou the led module is the same on both) vey good light, claimed 160lm, looks like it is compared to other lights, battery tube has flutes inside, even if cells leak they wont freeze inside. has flood to spot focus. cost me 25 few years back,
    Mar 2011
    Ohio, USA
    Default
    I see where you're coming from, when you want an XM-L or XP-G emitter. I really have to say, though that for the money, the new Mag LED 2D's are nice. I picked one up @ Home Depot for about $15.00. Get some clear spray paint to stipple the reflector, and you've got a nice floody beam with a subtle but well defined hot spot that's perfect for use around the house.
    Sent from my PC36100 using Tapatalk
    I wish one of our modders could find a way to churn out something with an XM-L cheap...even if they have to go to 3 C cells to do it but please no NiMH. I've had it with rechargeables. Just too expensive and too much trouble. I'll always have plenty of quality flashlights but I want a good dependable 2 D size that takes alkalines for the kitchen drawer.
    Would it really cost Maglight much more to use XM-L instead of XP-E? Why are American companies always so far behind the curve.
    Mar 2010
    TN
    For those emitters not sure you can meet your req. Malkoff is the only xpg I know of. Bullet proof and as simple as it gets. Drop in, tighten set screw, trim reflector. But more than you want to pay.
    Keep it between the ditches and the shiny side up.
    Sep 2009
    Washington, USA
    You won't get much benefit from an XM-L driven at a low current, and alkaline batteries cannot sustain the high current. That's why NiMH or Li-Ion is required for many of the XM-L lights.
    Have you looked at the Dorcy 6AA with XM-L? Check out the runtime graph for it, it's pretty bad. That's why NiMH is required, although I'm not sure why you're so against it. Eneloop AA's will stay charged for a long time, and won't leak. All you need to do is get an adapter and you're all set. That's what I do for my C- or D-cell lights.
    Mar 2010
    TN
    Elektrolumens makes the anglux with XML and xpg. Based of the Fulton 2D angle head. Prob as close as you'll get. And they are tough by themselves. With his led upgrade you get everything you want.
    Flashaholic* Sway's Avatar
    Aug 2003
    North Carolina
    Read your post.......buy a Fenix E05 AAA and a pack of Energizer L92 Lithium cells, if you need a little more light get a 4Sevens MINI AA or EagleTac D25A and a pack of Energizer L91 Lithium cells, if they don't have enough flood put some d-c-fix diffuser film to put over the lens.
    Alkaline cells are best kept in their pack till they are needed........the 2D Kitchen Drawer light always took up too much space
    Cheers
    Kelly
    Lucas Jackson, "Here, Captain"
    Maliciously destroying municipal property while under the influence, What was that?
    "Cutting the heads off parking meters, Captain."
    Dec 2007
    California Republic
    Quote Originally Posted by Sway View Post
    4Sevens MINI AA
    This is what I've been using for house lights (I have two) with excellent results; it has a big, broad beam that is indistinguishable from an XM-L. I've argued for some time that someone should make a 1D body for it, would make a perfect ceiling bounce candle.
    Flashaholic* Jash's Avatar
    Nov 2009
    Brisbane, Queensland, Australia
    If Mac makes them again, get one of his drop ins for a 3D maglite. It won't run on high for very long off alkalines but low and medium will run for ages.
    Beauty of the setup is that if the batteries leak, just buy a new host for the drop in. Might cost a bit more than $50 up front, but it's a beautiful floody beam that's great for around the house. You can choose from SST-50 or XM-L. PM him to see if he'll build one for you.
    There can never be too much honey to lick off your fingers.
    Flashaholic* HighlanderNorth's Avatar
    Sep 2011
    Mid Atlantic USA
    Wouldn't a 2-D cell light give you longer battery life than a 2 Cr123 light or similar?
    Some days you are the bug, some days you are the windshield.
    Quote Originally Posted by HighlanderNorth View Post
    very possible, 2d cells 3v 12000mah, 2 cr123 6v 1300mah.
    Flashaholic* JohnnyBravo's Avatar
    May 2011
    Planet Earth, USA, Idaho, Boise
    I think either a Duracell Daylite 2D, or a Maglite LED 2D would be fine for the kitchen. I just picked up a blue Maglite 2D LED at Lowe's on Black Friday for $14.97. I like the forward clicky button, and a fairly bright beam. I have a 2C Duracell; but the lumens is supposed to be the same as a 2D...
    I have more than I need, but not as many as I want.
    Surefire customer since 1995.
    ack NO alkalines
    What we need are decent NiHM C & D cells
    I hav eone of those first Fulton anglehead lights with a 1w Luxeon (two in fact one is at my parent's place)
    My dad really got a kick out of the old GI lights with an LED
    ack NO alkalines What we need are decent NiHM C & D cells
    I have one of those first Fulton anglehead lights with a 1w Luxeon (two in fact one is at my parent's place)
    Flashaholic* LEDninja's Avatar
    Jun 2005
    Hamilton Canada
    Quote Originally Posted by Double_A View Post
    Alkalines leak and ruin your flashlight. They are also the 1st items sold out in an emergency.
    Regular NiMH will self discharge to useless in a month. Not good for leaving in a kitchen drawer.
    LSD NiMH D (10000 mAH) are expensive. Walmart Canada sells Ray-O-vac hybrids at a reasonable price but at 2900 mAH vs 2000 mAH for AA it is simpler to go with an AA light.
    My suggestion is stick with alkalines but STORE THEM OUTSIDE YOUR FLASHLIGHT WHEN NOT IN USE.
    In addition to a 1 watt drop in for the military anglehead flashlight you can get Elektrolumens Anglelux-XML ($69.99).
    http://www.cpfmarketplace.com/mp/sho...x-XPG-goodness
    Default
    I don't like angle lights. I would prefer an xpg or xml in a 2 x d alkaline for under 50 dollars. If maglight can do it with xpe they can do it with xpg.
    Maglite LED 2D - simple and cheap
    Flashaholic* monkeyboy's Avatar
    Mar 2006
    UK
    I've got the Dewalt 2D cree XR-E flashlight which I bought for a highly discounted price; £50 down to £10 here in the UK. If you shop around you can find some good prices for this light. I guess no one is buying it at full price. Build quality is comparable to that of a maglite but has stippled metal reflector and glass lens.
    I also agree with the Maglite recommendations.
    It's silly to buy a nice enthusiast light like a TK50 and put alkalines in it.
    It's like spending all that time to make hand made pasta, and then pouring a can of ragu on it.
    Quote Originally Posted by Haelous View Post
    ????? it is made to work with alkalines.
    Quote Originally Posted by alpg88 View Post
    Why would you risk the batteries leaking with a nice light like that?
    Sorry, it just doesn't make sense to me...
    Flashaholic* Lighthouse one's Avatar
    Ephrata, Pa
    Dorcy makes a 2 D cell, and a 3 D cell. Ray o Vac has a nice 3 C cell sportsman extreme on sale at Amazon now.
    http://www.amazon.com/Rayovac-SE4W3C...392639&sr=8-48
    Good luck
    Striker VG, SL Scorpion Led, Huntlight FT01, Wolf Eyes 9 v Raider, D-Mini Lumapower, Drumlights, Surefire G2, Dereelight ,Ultrafire 500, Power on Board HID, Olight T 20 Q 5, Zebralight H-30, Nitecore EX 10, Eagletac T10C2, MTE P 7D, Icon Rogue 2
    I second the 2D MagLED Maglite. Only $15.88 at Home Depot. I have a 2D, and a 3D Mag with Malkoff. Granted, my eyes probably aren't as sharp as you flashoholics but I would need to have both with me to actually see a difference. Both throw far outside, though the 2D seems to be throw a cleaner beam. Lighting up the top of the palm tree in my neighbor's backyard who lives across the street, I can't really discern the "brightness" difference between the Malkoff 3D and the 2D MagLED.
    The batteries in the 3D are six months old though...not sure if that makes a difference.
    Mar 2011
    Ohio, USA
    Default
    The Malkoff's are definitely nice, and they are brighter, but for the money the Mag LED is the better buy.
