You can buy dozens or hundreds of different kinds of "LED bulbs", but none of them work safely or effectively in lighting devices designed to accept filament bulbs. The problem is at the concept level; it's not a question of waiting for someone to do it right or waiting for the right emitters to come along. It's an optic/source mismatch issue very much the same as why "HID kits" are dangerous (and illegal) in halogen headlamps. "LED bulbs" are also Federally illegal, because installing them violates the prohibition on "rendering inoperative" any mandatory item of safety equipment. This is not quite intuitive: "inoperative" doesn't just mean the stop light, turn signal, back-up light, parking light, tail light, side marker light, license light, etc. doesn't light up, it means its performance does not comply with the requirements. The requirements for even a simple-seeming lamp are actually quite complex to assure adequate safety performance in all operating conditions (light, dark, prolonged use, hot, cold, wet...) and through a large range of viewing angles. None of these aspects of performance can be assessed with the naked eye or handheld light meter or comparison to another lamp, etc., it takes special and very costly equipment. Lighting devices designed around LED light sources have to pass additional tests because of LEDs' thermal management issues; LED emitter temperature rises and light output drops with prolonged illumination...this is a tough test to pass, and none of the "LED bulbs" has anything like adequate heat sinking to pass it.
If you feel you would prefer LED courtesy lights, dome lights, glove compartment lights, and that kind of thing, go ahead. But you need to use the correct kind of light source in each of your vehicle's safety-related lights. To do otherwise is not just unsafe but illegal, and
rule 11 of this board prohibits advocating illegal activity.
