CLOSED >>>>Part 2 started on another thread thanks again
Reserved for Interested Members/orders
BarryH >>>>>1Lens>>>>>>>>PAID
BrianMc>>>>>3Lens>>>>>>>>PAID
jjohnson34>>>1Lens>>>>>>>>PAID
Mitro>>>>>>>4 Lens>>>>>>>>PAID
ranger07 >>>>4Lens>>>>>>>>PAID
Capt. Nemo>> 1Lens>>>>>>>>PAID
CMAG>>>>>>>4Lens>>>>>>>>PAID
Eric Sc>>>>>> 1Lens>>>>>>>>PAID
X Marine >>>>>10lens>>>>>>>>PAID
Hotrod76car>>>1Lens>>>>>>>>PAID
jgang>>>>>>>1Lens>>>>>>>>PAID
badtziscool>>>>2Lens >>>>>>>PAID
RCLumens>>>2Lens>>>>>>>>PAID
solo3937>>>>2Lens>>>>>>>>>PAID
Darvis>>>>>>2Lens>>>>>>>>>PAID
Supersand>>>2Lens >>>>>>>>PAID
sojah>>>>>> 3Lenses>>>>>>>PAID
oilp8ntr>>>>>1Lens>>>>>>>> PAID
Undrwater>>>2Lens>>>>>>>>PAID
__________________________________________________ ______________________________
SPACER SIGN UP
Bullyson1 spacer
DimLite 1 spacer/1 lens
Diablo_331
hotlight>>>>>>>>>>>>>>>>3 spacer kits >>>>>PAID
These are the same lenses that I've been selling for a while under the name 'ahorton'.
las3r is buying from me and reselling with my full support.
This should bring the prices down significantly for Non-Aussie buyers.
Compare las3r's prices (above) to my prices:
27.2mm Aspheric Lenses
1 - $35 each ($35 total)
2 - $22.5 each ($45 total)
3 - $16.67 each ($50 total)
4 or more - $15 each ($60 total for 4)
10 or more - $10 each ($100 total for 10)
20 or more - $8 each ($160 total for 20)
100 or more - $6 each ($600 total for 100)
As you can see, las3r's prices are much better in small quantities.
Also consider that they're not flying all the way from Australia, so you'll get them much quicker!![]()
I will take one
Thanks addictedmatt your added to the second post, u can pay anytime u like and ill update it with PAID and once i ship it out ill add the Date/ect.....
all clearedthe picture i used above was approved by Packhorse
Do I need special bezel ring to fit this aspheric lens on a Surefire stock 6P Z44 Head?or I can easily swap the stock lens?
Fits in most p60 hosts. Check your dimensions. You'll need at least 27.3mm diameter inside your head.....may be someone has the ID of that flashlight ? and ill try to keep records of every flashlight i hear of that this lens will work in![]()
For 'plug and play' you need the spacer kit as well as the lens. These are sold out right now. The easiest way to make your own adjustable kit is to drill out the reflector and raise the LED about 8-12mm in the pill.
The most common thing to do is to simply replace the original lens in a Surefire. Often this makes the aspheric protrude slightly, but if you don't like it then you can always get a longer bezel. The lens itself is very strong and I have never seen one break while installed in a flashlight.
i'm in for at least 1 if you stock the kit. Maybe 2 or more if the price is right.
Best way to reach me is via email
Those are sold out right now, but when there is some ill stock some.
I want an aspheric. Will it drop in a Solarforce L2p?
im not sure on the flashlights u guys have but for it to work >>>You'll need at least 27.3mm diameter inside your head
but ill do a search and see if i can find the inside ID for ur flashlight for u![]()
i had Pm'd a well none member here on CPF and will not say who unless he does not mind but this is what he said about the Solarforce L2p
It could fit, but it would be loose. Probably can be centered though. The lens area on the SolarForce is 30mm I.D.
And the lip that the lens would rest against is 25mm, so your lens would sit in there, it's just going to be a little loose, and will need centering as the bezel ring is tightened in place...
Put me down for one when you get some more in.![]()
Thanks Unenlightened u are added to the list on post#2
with the holiday coming im not sure how slow the shipping will be.............i say it will be on my doorstep in 7-10 days![]()
No I don't mind you saying it was me...
I happen to have a SolarForce host right on my desk, and the lens sits on a rim inside the head. That rim is a 25mm opening. (I.D.) The space for the lens O.D. to fit into, is a 30mm I.D. area.
So that means the lens will fit in there. And I'm sure that it can be centered with very little effort...
Thanks Jay for the info, BarryH payment received u will be the first package to ship out once i get them.
That means that the lens will fit but will be a little loose inside the host, You might have to be creative and find/make a centering ring, may be from a PVC pipe? if u can find one that will work, on my last build i used black rubber silicone to hold my lens into place and it also made it water proof![]()
Here is an example............2nd pic
http://www.candlepowerforums.com/vb/...00-lux-1-meter
hrm....I'm not that handy when it comes to this project. I really want the aspheric, but fear it's going to be a challence. Maybe if I could find an o-ring, or something that fits?
That will work, all it needs to do is hold the lens in the center so it does not wiggle around. my hardware store sells tons of different size O-Rings
updated the first post at the bottom![]()
BrianMc received your payment... 2nd post updated
Hi las3r, paypal sent. Please get back to me when you can.
Thanks jjohnson34, i added u to the 2nd post and will update everyone's order on Monday or Tuesday with tracking.........HAPPY Holidays
2ND post updated for the following buyers
jjohnson34 sent u a question about your address thanks
