HDS Systems
Results 1 to 4 of 4
Thread: My Skyline 2 modified to XM-L @ 1.4A
    Flashaholic* old4570's Avatar
    Feb 2009
    Melbourne - Australia
    Default My Skyline 2 modified to XM-L @ 1.4A
    Well , when I first got the Skyline 2 , I was like , Im not going to mod this light !
    Then the XM-L emitters came out , and I was like , " I should mod the Skyline 2 " [ Then I had to go to school = Bummer ]
    Well , Schools out , and Ive been catching up on my home work [ Modifying Flashlights ] , yeah , the important stuff .
    Just let me say right up front , Modding the Skyline 2 is a PITA ...
    Why you ask , because the darn pill is glued in , and mine was glued hard , real hard ...
    It took a serious amount of heat to get the pill out :
    In fact the XR-E emitter floated of its base [ de soldered ] , before the pill would budge ...
    To get mine out , I drilled two holes , for needle nosed pliers to go in to twist it out , but I needed lots of heat , and multi grips and lots of swearing [ the swearing was mandatory and Im sure I entertained the neighbours during the pill removal ]
    The next PITA was removing the emitter base , again seriously glued in place ...
    Check out the abuse the pill has taken : Solarforce really put the Skyline 2 together with a lot of glue , %&(*Y^%$&^%^$ Solarforce !
    Now you might think it gets easier from here , wrong , the next PITA is removing the old driver ...
    The way it works is , the driver is poped inside just under the emitter , the brass ring is pressed over the top of it , so it sits just under the emitter and a contact pad is pressed over the back of the pill , so the driver sits deep inside the pill , and the only way to get it out =
    Mash it good , and scoop it out ....
    Once the pill is out of the body , the emitter removed , the driver smashed and scooped out ,
    You can think about what your going to put in ..
    Bear in mind that the ramping feature is in the tailcap , so pick a single mode driver ..
    Pictured is my XM-L T6 [ 5000K tint ] and a 1400 4 x 7135 driver ...
    The XM-L glued in place ...
    The driver soldered ... At this point I test to make sure things work ..
    Then I solder the driver in place at the back of the pill ...
    I ever so slightly damaged the body removing the pill , *(*^^$&%&(*))(*&*&%$% Solarforce
    Front of the Skyline with the XM-L in place ...
    Measuring current from the back [ less tailcap ] = 1.44A with a Xtar 18700 , I would expect a small loss with the tailcap in place ..
    But I have to say the beam is nicer than the XR-E original , the ramping work perfectly ...
    Cant wait till it gets dark , ill post some beams ..
    I have really grown to dislike the XR-E , the very small hotspot is a pain to use at close range , as it makes it hard to see anything except whats in the tiny hotspot ..
    XM-L has really spoiled me , I love XM-L .. For around the house , the XM-L rules , and for anything out to 100 Meters the XM-L works well , and a XM-L thrower will extend that out to 200 Meters , I dare say the days of the XR-E are numbered , and Im so over tight narrow pencil beams , they are just not practical .. For everyday use , for making it easy to see everything at night , the XM-L rules the roost . It does what the MC-E SSC P7 does but better , cheaper , and easier ...
    Though the Skyline 2 mod was a serious PITA , the result looks to be worthwhile ..
    Beams tonight ...
    Some output figures : [ Fresh of the charger Xtar 18700 ]
    High = 455L
    And the lowest it will ramp down too is 6L
    Low 6L
    High 450+
    Really bad video of the ramping ,
    *Flashaholic* Illum's Avatar
    Apr 2006
    Central Florida, USA
    Default Re: My Skyline 2 modified to XM-L @ 1.4A
    I like it, very clean beam... remarkable free of artifacts considering the reflector was meant originally for an XRE
    Hi old4570, nice new light you have there. Nice big hotspot there on the wall. Seems by the pic it is almost to bright on high. Now I know what that old song meant by "I have to wear my sun glasses at night".
    Feb 2009
    Yes , the white walls tend to bounce back a lot of light .. [ To much light ] Yeah , 450L is a little much for the back yard , I find around 250L is about right to see really well ..
    One day I will have to look into re programming the drivers .. [ Multi mode drivers ]
    Due to the Skyline having a ramping driver , I just posted Highest and lowest ... [ And the camera really takes bad video ]
