Results 1 to 21 of 21
Thread: Heads and bodies compatibility
    Default Heads and bodies compatibility
    I know the Logan head will fit on the McKinley body, but I'd like to find out if the Logan head is compatible with any other currently available lights like the Ranier or Pamir. I looked but could not find a thread on this.
    Jan 2006
    Arnieland
    Default Re: Heads and bodies compatibility
    I believe the Eiger head will fit on the Vesuvius body. I was going to pull the trigger on the Rainier but backed out in favor of the Logan. Would still like to pick up an Everest.
    Funniest CPF thread ever. I promise it'll make your day.
    The diameter of the Eiger head is too small for the Vesuvius but the Shasta heads do fit. I run a Shasta X on a Vesuvius body.
    I also chose the Logan over the Ranier mostly because I think the Ranier is a good candidate for the next XML led upgrade.
    My reasoning regarding the Pamir and Ranier is that they, like the Logan all use a 3/4 inch head.
    May 2009
    The Logan and Pamir are theoretically compatible.
    Pyrenese, Night Patrol and Ural are compatible with each other AFAIK.
    eala
    Flashaholic* archimedes's Avatar
    Mar 2011
    CONUS, arteriosus
    Quote Originally Posted by jorgen View Post
    Yes, I think that the Logan will fit McKinley/Rainier/Pamir interchangeably, and can personally confirm Logan/Rainier will work. Possibly also Atlantic, but I don't have one to check.
    IF 2 = 1 THEN 1 = 0
    Quote Originally Posted by archimedes View Post
    Thanks for the info, are the body lengths of the Logan and Ranier the same?
    Mar 2011
    CONUS, arteriosus
    No, the shortest would be the Logan (CR123), then the Rainier, and the longest would be the Logan (17500) - if all tubes are the keychain versions. The widest, of course, would be the bezel on the Rainier - but it has a large SMO reflector and should have much more throw than the Logan....
    IF 2 = 1 THEN 1 = 0
    That is body lengths without heads, right?
    Mar 2011
    CONUS, arteriosus
    No, it was for the total length of the assembled light. For just the tubes, obviously the 17500 would be the longest, and both CR123A tubes would be shorter (and of very similar length, if not exactly the same, since I think Peak machines them in batches and uses them interchangeably for these thread-compatible models).
    IF 2 = 1 THEN 1 = 0
    Okay, thanks again, that's what I wanted to know before making my final decision. I'd like to put the Ranier head on a Logan 17500 body for longer run time
    Mar 2011
    CONUS, arteriosus
    Don't forget, it can get HOT if you run it on max for a long time....
    IF 2 = 1 THEN 1 = 0
    Sep 2005
    Glendale, Arizona
    Just a couple notes about sizing & compatibility.
    The Everest, K2, Pyrenees and Ural all have bodies that can accept 18mm diameter batteries, although none of these have threading compatible with the Night Patrol series (this is to prevent use of multiple battery Night Patrol bodies and therefore more voltage than the pocket series can handle). There are 16340/18350 & the longer 18500 bodies for each of these lights, but none of these have threading compatible with the Logan class lights listed below.
    Subject to the possibility that portions of my brain function have been degraded by age or environmental factors, I believe the Logan, Pamir and Rainier (as well as the older Atlantic, Caribbean, Glacier Bay, McKinley & Mediterranean) heads, all fit the same single CR123 or 2XAA bodies. Length of these bodies varies, of course, with the shorter pocket and longer keychain/momentary styles. Newer production is also slightly longer to accommodate the QTC. The new 17500 Logan body will accept any of these heads, and with the battery conversion kit it is without any doubt an incomparably versatile battery compartment.
    Peakaholic!
    Flashaholic* gunga's Avatar
    Nov 2006
    Vancouver, BC, Canada
    I'm interested in an alternative head for my Logan bodies, can someone comment on the circuits in each?
    I know the Logan has the same circuit as an Eiger/El Cap so they can run on AAs etc. The Ranier is direct drive so really is best with Li-on batteries. How about a Pamir? Any other alternatives? Is the Logan still best for multi voltage sources like the 17500 body?
    Mar 2011
    CONUS, arteriosus
    Default
    Quote Originally Posted by gunga View Post
    I know the Logan has the same circuit as an Eiger/El Cap so they can run on AAs etc. The Ranier is direct drive so really is best with Li-on batteries. How about a Pamir? ....
    The Pamir was sold in a 2xAA version.
    IF 2 = 1 THEN 1 = 0
    Nov 2006
    Yes, I know, but I mean can the Pamir run on 1AA like a Logan?
    May 2009
    Well, I can confirm that the Pyrenees lights up on 1xAA NiMH cell. Not sure how long it will run for, but it has decent brightness.
    (had to hand-jumper it)
    eala
    The Volcan AAA and Titanium Mach 3 AA have interchangeable heads and bodies.
    I was very pleasantly surprised to discover that they are interchangeable.
    If this is also true of the AA Volcan and I could buy just a body, I'd get one.
    The Pacific set I recently purchased, in the marketplace, is also compatible with the Volcan/Mach3.
    Mar 2011
    CONUS, arteriosus
    Thanks very much for adding this data point to the list ....
    IF 2 = 1 THEN 1 = 0
    Oct 2007
    Sitting' on the dock o' The Bay...
    I want to compile a list of the various lights that are compatible with each other. Of course, I'm new to Peaks so I don't know much about them nor the different models, just what I'm seeing here and what little I've learned along the way. That means that I'll need guidance with this compilation in order to make it complete and, hopefully, comprehensive.
    From smallest to largest:
    AAA batteries - Matterhorn, Eiger, Fujiyama
    N cell, AAA batteries - Shasta, Baltic Sea, Vesuvius
    Okay, I need help from here...
    Apr 2008
    Cleveland,Oh
    It will be vary hard to do by battery type. There are Baltic/Shasta bodies that are AAA etc.
    The best way may be by compatible threading.
    A good place to start will be MWClint's sticky. Many of the current lights are revisions of those from the past.
    Great spirits have always encountered violent opposition from mediocre minds.
    -- Albert Einstein
